PTO Driven Water Pump?
/ PTO Driven Water Pump? #1
HoggyB
Hi, all-
I'm having trouble finding PTO driven water pumps that mount to the 3 point hitch. I found this one at Northern Tool (actually, would that thing connect to the 3 point hitch?...) but it only provides 20 GPM and I was hoping to at least double that.
What I want is something I can connect to my water storage tank and use for firefighting purposes. (The pump on my well puts out 35 GPM which is pretty good out of a garden hose (or two), but I'm thinking more would be better.)
I've found some funky looking pumps that look very specialized, but what I really want is something like the one at Northern Tool only BIGGER.
Hog
/ PTO Driven Water Pump? #3
hoggy:
The auxiliary pump on our "brush truck" puts out almost 100 plus gallons per minute to two 1.5 inch hoses. If we are drafting or feeding from a tanker we can fight small fires but if not, we are going to run out very quickly. Can you say air tanker?
Suggest that your emergency plans start with 911
</font><font color="blue" class="small">( I got bigger.
http://www.kifco.com/kcpump.html
http://www.crisafulli.com/trailer_pumps.htm
http://www.cadmanpower.com/asp/Public/Products/products_details.asp?type=1&cat=1
http://www.thomasregister.com/olc/69466001/fspto.htm
)</font>
Now THAT'S what I'm talkin' about!
The Kifco D2/40 looks like it might be perfect. How do you size these things? The D2/40 says it will squirt 150 GPM at 133 PSI and 21HP. Will this work with my BX23? It has a 21HP motor, but does that translate to 21HP at the PTO?
Hog
</font><font color="blue" class="small">( hoggy:
Suggest that your emergency plans start with 911 )</font>
They do. They also start with fuel reduction. But I have a 12,500 gallon water tank sitting next to my house (thanks to the fire department, and believe me I'm not complaining) that I want to be able to tap into. Just as an alternative...
Hog
/ PTO Driven Water Pump? #7
</font><font color="blue" class="small">( What I want is something I can connect to my water storage tank and use for firefighting purposes )</font>
firefighting what? in case your house starts on fire?
