PTO driven water pump
/ PTO driven water pump #11
I built one from a small fire truck pump one time. I didnt have ater at work just a large spring fed pond. I put a tank on a truck and needed a wa yto fill it without a small motor. I traded for a small 3 inch inlet and outlet pump off an old mid 70's ford one ton pumper truck. It had a step gear box to speed the pump speed. THis made it turn the right rotation for a 540 pto. I mounted it on an old carryall frame and put a pto shaft on it. THe suction side faced the rear so I made a 4 bolt flange to hold a 3 inch galvanized conduit with a long bend in it. I made an adapter to hook a 3 inch ose to the top discharge. It worked great spraying water 10 feet straight up in the air. I could fill our 1000 Gallon water tanker in about 5 minutes.
My brother built a 2000 gallong water truck and I donated the pump to his project. Ive seen one made from a long pipe like the one posted above but in one end it had a 2 blade prop made from sheet plate. It had a speed increaser on the input side where the tractors pto attached made from pullies.
At work to water the garden our water tanker is a rolloff ttruck that has a homebuilt tank we can set off. We stick the suction hose on our pto sprayer pump on it we have a set of hoses that adapt it to a garden hose. On a stock 540 pto we can run 2 of the adjustable water sprinklers at almost full capacity on the end of a 100 foot T hose. On my Yanmar with a 4 speed pto 3rd gear I can idle the motor and run the 2 sprinklers at 100 percent. A higher idle in 3rd will blow the seals in the sprinklers.
/ PTO driven water pump #13
Can you post a picture of your setup? I need to move water from a river into a tank to water my garden and was looking for an inexpensive setup. What type of a pump did you find for so little money?
I just put a watch on ebay for pto pump and when it came up bid on it and got it.
It's similar to this one from Northern Hydraulics for $99. It's mounted on a piece of angle iron with a chain to hold it on the tool bar and a short straight shaft to the pto. If I can find it I'll post a photo. One of the best parts of the one I bought is that it was only about 40 miles away and the guy worked with my neighbor so it was free delivery to my door.
For a real cheapy just to water the garden, I'll bet anyone could easily adapt an old electric well pump if you can find one with a bad motor. Just yank off the motor, fab some brackets and pto shaft (or maybe belt drive) and pump away. Maybe even an automotive water pump would work but I don't know how far it would pump.
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
John Deere XUV825E (A61307)
John Deere XUV825E...
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
Giyi-D39 QA Trencher (A60463)
Giyi-D39 QA...
Informational Lot - Shipping (A61307)
Informational Lot...
2011 FOREST RIVER SIERRA CAMPER TRAILER (A60736)
2011 FOREST RIVER...
