PTO driven Leaf Collection
   / PTO driven Leaf Collection #1
Thomasre
Bronze Member
North Carolina
Kubota L3430 + BX2230
Can anyone suggest a leaf collection system for a JD 4400? Ideally, it would work with belly mower operating and have a shoot to a collection system mounted on 3pt. hitch. Would or could Rear PTO assist to provide additonal suction into collection system attached to 3 pt. hitch? I don't even know if rear pto will operate with belly mower running?
Thanks in advance.
   / PTO driven Leaf Collection #2
Here is what it sounds like you are looking for:
<A target="_blank" HREF=http://www.giant-vac.com/1_0a_4.html>http://www.giant-vac.com/1_0a_4.html</A>
Giant Vac well known where I grew up and everyone I have talked to has had good luck with thier products.
JT
   / PTO driven Leaf Collection #3
I've recently purchased a similar system from a different vendor <A target="_blank" HREF=http://www.trac-vac.com/>Trac-Vac</A>. They offer both PTO driven vacuum systems and self-powered (motor on vacuum trailer).
Based on a recommendation from my dealership, I chose to get the one that has its own engine on the system (Model 860 to be specific)...the logic behind that decision is that since I don't have live power to the PTO, when I clutched/stopped, the mower deck blades would keep turning, but the suction to the vac would stop (due to the clutch). By having a self powered system, there is always suction to the system regardless of the clutch status -- so there are many fewer clogs to worry about. I've used my about 16 hours with no chute clogging.
   / PTO driven Leaf Collection #4
John Deere has a Materials Collection System (MCS) available that has its own separate engine. In addition there is a PTO system available from Trac-Vac (www.Trac-Vac.com). In answer to your question about PTOs, yes both Mid and Rear PTOs can be run either simultaneously or separately.
Jack
   / PTO driven Leaf Collection #5
Other links for vacuum systems, for your consideration:
<A target="_blank" HREF=http://www.bluebirdintl.com/products/vacuums_chippers/index.html>Bluebird International</A>
Goossen TurboVac
Mathews Lawn Genie
