PTO driven generator
   / PTO driven generator #1
RonJ
Fort Worth, TX
I have a Yanmar 1700D and would like to mount a generator powered by the pto. The generator needs to be driven at 1800 rpm. I'd like to use belt and pulleys to increase the pto's 540 rpm. Will someone point me to a web page that will help figure out the correct size pulleys needed? Any advice, recommendations etc. are welcome. Thanks.
Thanks for the info. Looks like the first will do it.
   / PTO driven generator #6
Just a word of advice. I used to run a 15 KW PTO set with my JD 770 (Yanmar). Worked very well, albeit the tractor screaming away at FULL RPM. Thought I could use a 2:1 gearbox and run the tractor at half RPM. Many times during a power outage you only need a few hundred watts. Anyway, the tractor would not even run that thing in that configuration with no load at all on the genset. Guess it was just out of its power band.
   / PTO driven generator #7
Just a word of advice. I used to run a 15 KW PTO set with my JD 770. Worked very well, albeit the tractor screaming away at FULL RPM. Thought I could use a 2:1 gearbox and run the tractor at half RPM. Many times during a power outage you only need a few hundred watts. Anyway, the tractor would not even run that thing in that configuration with no load at all on the genset. Guess it was just out of its power band.
The reason to run the tractor engine at rated rpm is to provide sufficient angular momentum to the generator when a large electrical starting load is applied. Run it just slightly below the peak torque rpm. That gives the governor the best accelerating control as needed. The motor was designed to run at rated rpm, too. For mechanical durability (motor mounts too) as well as fuel economy.
   / PTO driven generator #8
get a gear increaser set. many heads are 3600 rpm and simply have a 540-3600 box. you can get them for whatever poles you need. ( 540-1800, etc. )
better than belts, IMHO.
   / PTO driven generator #10
I think 12kw will be stiff on a 1700.. I moved my Gen off my 1700 to an 8n ( then a 660 ) for continuous high load. Extra hp and flywheel handled large starts better
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
John Deere 893 Corn Head (A50514)
John Deere 893...
JMR Attachments 40" Mini Grapple (A50121)
JMR Attachments...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2015 Chevrolet Equinox SUV (A50324)
2015 Chevrolet...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
