PTO disengage while runing
   / PTO disengage while runing #1
zenonmb
Fiat 600E 1977
I have an old fiat 600, from 70’s that after running 20 mins with a lawn mower, the pto disengage.
Also noticed that when trying to engage pto it makes noise( gears noise).
So it sounds like two problems.
Not easy pto engagement and pto disengagement while running
With the tractor stopped, if i press the clutch to the end pto is released, i can move it by hand. But when running something changed inside and pto even with full clutch, it is still stucked.i mean, it still spinning, no change on speed
Was thinking to reduce clearance between pto fingers and thrust bearing, but i see the pto disc moving like 1 mm with the tractor stoped, so not sure if needed.
Any advice?
   / PTO disengage while runing #2
When engaging the PTO I throttle down to idle, depress the clutch, engage the PTO, then bring it up to PTO speed. To disengage the PTO depress the clutch first. Not doing this can cause excessive wear on the gears and may lead to the PTO disengaging on its own. I'm not saying that's your case, just saying it's a possibility.
Well , this is how I usually use it.
2014 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2014 UTILITY VS2RA...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2014 Freightliner M2 106 Bucket Truck, VIN # 1FVACXDT2EHFU7070 (A57453)
2014 Freightliner...
2014 Chevrolet Silverado1500 Pickup Truck, VIN # 1GCNCPEH0EZ393232 (A57453)
2014 Chevrolet...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
1983 Ford 8000 Tandem Grain Truck (A59814)
1983 Ford 8000...
