Rear Finish Mower pto connection
/ pto connection #1
marcopolo
Farmall H
I own a 1946 Farmall H with a front end loader attached. I recently purchased a brush hog to attach to the pto. The front end loader hydaulic is connected to the pto, but there is a female opening available on the back of the unit. My problem is that the brush hog also has a female connection (standard), so I need a 6 spline double ended (male) connector to attach the brush hog to the pto without messing with the hydraulics. Does anyone know what this piece of equipment is called, and where can I locate such a piece ?
Thanks in advance for your help.
Marco
Berthoud, Colorado
/ pto connection #2
I also have a '46 H and recently got a pull-type Bush Hog for it. No front loader, though.
I had to add a slip clutch and an over-running coupler to the PTO shaft, did a good bit of shopping around for adapters. I looked back through some of the links I saved and I'm afraid your male/male adapter is like the reverse direction over-running coupler I wanted: a fine idea no one's had yet. I did see an adapter with an extra-long shaft for pto pumps
http://www.baumhydraulics.com/files/catalog/s15.pdf
You could cut the female end off and grind a groove or drill for a pin, but they want $135 for it. Or get two of the ten dollar extensions and weld them together. Getting a bit far-fetched here.
Do you have a three-point on your H or is the mower a trailer type? I ask because adding length to the shaft at the tractor end moves the tractor-end u-joint farther out and makes it do more of the angling.
Good luck, Wm
/ pto connection #4
yep.. get a long adapter if you need to run a hog off the end of the sahft aft of the pto pump.
soundguy
/ pto connection #5
I know this is an old post, and Marcopolo hasn't been active since it came up, but I was looking for something similar for a project, and happened across this thread. I found something that will work for me, so maybe others will benefit from this as well: 12 inch 6 spline 1 3/8" male-male PTO shaft.
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2021 Tesla 3 Sedan (A61569)
2021 Tesla 3 Sedan...
2024 John Deere 8R 250 Tractor (A63109)
2024 John Deere 8R...
2013 JOHN DEERE 7700 PRECISION CUT FAIRWAY MOWER (A62130)
2013 JOHN DEERE...
NORTON CLIPPER C-139 CONCRETE SAW (A62131)
NORTON CLIPPER...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
