3-Point Hitch PTO Clutch
/ PTO Clutch #1
texoak51
owasso,ok
kubota m6800dt
Hello guys, I have a question I need an answer to if you will. The Pto clutch engagement warning light on my dash comes on at random when I have the PTO engaged. According to the manuel, it should be on anytime the PTO clutch is engaged. I,m just curious if there is a problem I need to be concerned with since it only comes on at random instead of instantly when I engage the clutch. My tractor is an M 6800hst 4 wheel drive. Thanks
/ PTO Clutch #2
It sounds like a loose wire or bad sensor. Probably not a mechanical issue.
larry
/ PTO Clutch
Thanks, I didn,t think it was a big deal but you never know.
2014 FREIGHTLINER CASCADIA (A65643)
2014 FREIGHTLINER...
2011 Ford F150 (A66408)
2011 Ford F150...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2022 CATERPILLAR D1 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
(10) Field Cultivator Shanks (A65640)
(10) Field...
2019 AUTOCAR XPEDITOR TRASH COMPACTOR TRUCK (A63276)
2019 AUTOCAR...
