3-Point Hitch PTO Clutch
   / PTO Clutch #1
texoak51
owasso,ok
kubota m6800dt
Hello guys, I have a question I need an answer to if you will. The Pto clutch engagement warning light on my dash comes on at random when I have the PTO engaged. According to the manuel, it should be on anytime the PTO clutch is engaged. I,m just curious if there is a problem I need to be concerned with since it only comes on at random instead of instantly when I engage the clutch. My tractor is an M 6800hst 4 wheel drive. Thanks
   / PTO Clutch #2
It sounds like a loose wire or bad sensor. Probably not a mechanical issue.
larry
   / PTO Clutch
Thanks, I didn,t think it was a big deal but you never know.
2008 International 4400 Pumper Fire Truck (A50323)
2008 International...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
Coats CHD-9551 Tire Charger (A50121)
Coats CHD-9551...
2000 Ford F-150 Pickup Truck, VIN # 1FTRX17W7YNA75070 (A51572)
2000 Ford F-150...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
