pto clutch break-in
   / pto clutch break-in #1
Mojoman
okay, I forgot to do the break-in procedure on my pto, only mowed a couple of times. Is it pointless to run the procedure at this point or is the damage done?
   / pto clutch break-in #2
I wouldn't sweat it. If you've mowed with it, it's fine. I think the 10 on/off 'break-in' cycles is for the dealers to verify the clutch holds (air gap set right) nothing comes apart, stops working, or no belts fly off! They've got the science down-pat on lawn/garden tractor electric PTO clutches these days. They either work or they don't /forums/images/graemlins/grin.gif!
G/luck
Joel
/forums/images/graemlins/grin.gif Yeah, nothing flew off /forums/images/graemlins/shocked.gif, so I guess I'm good to go! Thanks JT
Now, I've gone through the manual to confirm the type of oil I'm supposed to use, and it says cub cadet brand 10w-40 (i believe, I'll dbl check) rating SL or SG (or higher?). Can I use conventional automotive motor oil as it tends to be rated better than this?
   / pto clutch break-in #4
</font><font color="blue" class="small">( /forums/images/graemlins/grin.gif Yeah, nothing flew off /forums/images/graemlins/shocked.gif, so I guess I'm good to go! Thanks JT
Now, I've gone through the manual to confirm the type of oil I'm supposed to use, and it says cub cadet brand 10w-40 (i believe, I'll dbl check) rating SL or SG (or higher?). Can I use conventional automotive motor oil as it tends to be rated better than this? )</font>
I used the same automotive oil that I used in my cars for 26 years in my CC 1450 (usually Quaker State 5W-30) and am using it now in my 3235. When I had to replace the oil pan on the 1450, due to wear from missing mounting bolts, the engine was spotless inside with 800-900 hours.
Bob B.
ASSORTED NYLON SLINGS (A54757)
ASSORTED NYLON...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
CATERPILLAR 535C SKIDDER (A52707)
CATERPILLAR 535C...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2007 STERLING A9500 DAY CAB (A56129)
2007 STERLING...
