pto clutch break-in
   / pto clutch break-in #1
Mojoman
Bronze Member
okay, I forgot to do the break-in procedure on my pto, only mowed a couple of times. Is it pointless to run the procedure at this point or is the damage done?
   / pto clutch break-in #2
I wouldn't sweat it. If you've mowed with it, it's fine. I think the 10 on/off 'break-in' cycles is for the dealers to verify the clutch holds (air gap set right) nothing comes apart, stops working, or no belts fly off! They've got the science down-pat on lawn/garden tractor electric PTO clutches these days. They either work or they don't /forums/images/graemlins/grin.gif!
G/luck
Joel
/forums/images/graemlins/grin.gif Yeah, nothing flew off /forums/images/graemlins/shocked.gif, so I guess I'm good to go! Thanks JT
Now, I've gone through the manual to confirm the type of oil I'm supposed to use, and it says cub cadet brand 10w-40 (i believe, I'll dbl check) rating SL or SG (or higher?). Can I use conventional automotive motor oil as it tends to be rated better than this?
   / pto clutch break-in #4
</font><font color="blue" class="small">( /forums/images/graemlins/grin.gif Yeah, nothing flew off /forums/images/graemlins/shocked.gif, so I guess I'm good to go! Thanks JT
Now, I've gone through the manual to confirm the type of oil I'm supposed to use, and it says cub cadet brand 10w-40 (i believe, I'll dbl check) rating SL or SG (or higher?). Can I use conventional automotive motor oil as it tends to be rated better than this? )</font>
I used the same automotive oil that I used in my cars for 26 years in my CC 1450 (usually Quaker State 5W-30) and am using it now in my 3235. When I had to replace the oil pan on the 1450, due to wear from missing mounting bolts, the engine was spotless inside with 800-900 hours.
Bob B.
H & S High Capacity Hayrake (A50515)
H & S High...
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
EZGO (A50324)
EZGO (A50324)
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
