PTO Clutch and Ground Drive Pulley failure
   / PTO Clutch and Ground Drive Pulley failure #1
rahess
Well, I'm on my fourth PTO Clutch and I really need help to make sure this one lasts.
I believe my clutch failures are actually a result of the Ground Drive Pulley / Engine Pully upper collar going to pieces.
So the question is what is causing the upper collar of the pulley to go to pieces.
I know the clutch and collar are being compressed on the shaft by the mounting bolt.
The upper collar contacts the radius of the engine shaft, and under the pressure, just keeps failing. I don't know what I'm doing wrong.
The Warner Electric installation guides for the PTO Clutch say that you should chamfer the pulley collar end to clear the radius on the engine shaft, but that just seems to me would weaken the collar even more with the outward pressure just causing another failure. The collar is only about 1/8" thick while the radius on the shaft is probably close to 1/4". So I don't see how chamfering the collar would be a good thing.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2004 TRAVIS 48' WALKING FLOOR REFUSE TRAILER (A53426)
2004 TRAVIS 48'...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
