PTO Chain?
   / PTO Chain? #1
CANdiyMXER
MX5000
What is the purpose of the small chain on a PTO, is it simply to keep the PTO from separating?
   / PTO Chain? #2
Hook the chain onto the tractor or implement. It keeps the plastic PTO shield from spinning with the shaft.
   / PTO Chain? #3
Yes, its supposed to stop the PTO cover from rotating. In my experience it just breaks loose, and scratches the paint off of everything it can reach. I now just remove them and accept the associated safety hazards.
   / PTO Chain? #4
[which are approximately none]
   / PTO Chain? #5
Interesting... I have not had any troubles with my PTO chains. Use them every time.
   / PTO Chain? #6
just grease both niple at the end of the shield and you wont break the plastic bearing who hold the chain
   / PTO Chain? #8
thanks for the orginal question. I thought that's what they were for, but was not sure. One attachement i purchased was made to use the stay chains, but the dealer did not have them on when it was sold/delivered. I've since added them.
   / PTO Chain? #9
So far, I've only had my RC for one season, but the PTO shaft cover spins very freely. I can't imagine how the chain would break. (It hasn't.) Perhaps if it starts filling with some sort of matter (grass clippings, dirt) over the years, it might start getting stiff and impede the rotational efficiency. I would imagine keeping it clean would be a big factor in its continued operational status.
Joe
   / PTO Chain? #10
mjym Re: PTO Chain?
This is stated correctly. If you grease the sheild zerks it will allow plastic parts to rotate easly and the light chains will not break under normal conditions.
378798 (A51573)
378798 (A51573)
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
378696 (A51573)
378696 (A51573)
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
