PTO Capstan Winch (from scratch)
/ PTO Capstan Winch (from scratch) #81
Hi, As a lifelong wharf rat I know that nylon is preferred as an anchor line because the stretch helps prevent jerking you around ( and pulling out the anchor) PolyDacron is probably a much better choice. They have some on Amazon
When winching, you do not want stretch. Most capstan winches use double braided polyester rope: minimal stretch, decent abrasion resistance (at least as ropes go). Nylon generally has too much stretch for this application.
For rope, I first tried 3/8" synthetic winch rope. One trip through the winch, and that rope is now pancake flat. Next I tried 5/8" double braided nylon rope. That worked well until outer cover got a small tear on it, and then it quickly unraveled. Finally I settled on 5/8" three-strand-twisted rope. It is holding up the best, but nevertheless the winch is very hard on any rope you run through it. I expect to replace the rope fairly frequently.
If your winch is really eating up ropes quickly, you may have a problem with the surface of your capstan. It could also be a matter of just using the wrong type of rope, but the condition of the capstan surface and anything else that comes in contact with the rope is the first place I would look.
/ PTO Capstan Winch (from scratch) #82
My capstan has an aluminum drum and I have not had any issues. But my ropes are not extremely dirty.
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
(4) Trail Quest 225/75R/15 Tires and Rims (A64047)
(4) Trail Quest...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
2012 International (A59230)
2012 International...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
