PTO broke?
   / PTO broke? #1
BWSSR
Madisonville, Texas
Kubota L3200
Was bush hogging w/1500D, and and as the front dropped into a hole, the brush hog hit a hidden stump. Tractor went bang, hog stopped turning, and lever for the PTO speed became free moving. What did I break?
   / PTO broke?
so I pull it, then rebuild? or is there 1 or more pieces that I broke?
   / PTO broke? #4
No way to know without inspecting it.
   / PTO broke?
I'll drag her home, then pull her down. Thanks
   / PTO broke? #6
Look at the mower and find out why the shear pin/clutch didn't work also, or it will probably happen again.
   / PTO broke? #7
this would be my question as well, also were you running direct drive-line to the PTO without a overrun clutch?
I have read here on TBN someone else had broke their PTO output shaft, this would be the best scenario, although by you sugesting the PTO lever has no action then I'd say worst case scenario (broken gears):cool:
   / PTO broke?
I had an over run on it, and it self destructed. I can spin the shaft and the mower and output shaft move/roll. I didn't try it, but it running, but the lever will go into the 3rd position, just not 1 or 2
2018 Doosan DL220-5 Articulated Wheel Loader (A53421)
2018 Doosan...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
Kawasaki NR (A50324)
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
