PTO BLOWS FUSE AFTER REPLACING DRIVE BELT ON LT 1042
   / PTO BLOWS FUSE AFTER REPLACING DRIVE BELT ON LT 1042 #1
bamaman01
Section Al
cub LT1042
I replace drive belt and reinstalled clutch and now when i engage pto it blows a fuse and cuts mower off. Clutch seemed to go back on without trouble. What is the problem. I need help quickly. I need to mow or just get some goats to take care of my yard.lol please help me, getting frustrated!
   / PTO BLOWS FUSE AFTER REPLACING DRIVE BELT ON LT 1042 #2
Did you pinch the clutch wire?
Dave
   / PTO BLOWS FUSE AFTER REPLACING DRIVE BELT ON LT 1042 #3
It's easy not to get the PTO retaining rod back into the correct notch. If the PTO twists it will pull on the wire and blow the fuse. I did this the first time I changed the PTO belt. Check the rod to make sure it is in the correct notch in the PTO.
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
43055 (A55851)
43055 (A55851)
2021 CAT SKID STEER (A55973)
2021 CAT SKID...
2016 Ford F-350 Super Duty Pickup Truck, VIN: 1FT8W3DT1GEB84319, Crew Cab, 4x4, Steel Flatbed (A59076)
2016 Ford F-350...
FENCE PANELS (A58214)
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
