PTO attachment for Cyclone seeder - help needed
/ PTO attachment for Cyclone seeder - help needed #1
penrod72
cny
kubota 7200
I have access to a 3 point hitch mounted Cyclone seeder. It runs off the PTO, via e flexible cable. I have been told the pictured coupler goes to the PTO on other people's seeders, and the small end attaches to the flex cable with a pin (this I have seen). I have been told the connection to the PTO is held on via allen head screws. However:
- the holes on the side that should slide over the PTO are not threaded.
- the end that should slide over the PTO is not splined to fit on the PTO and catch, so it would not spin
- the larger end that should go over the PTO does not fit over my PTO (Kubota B7200 that I run other PTO equip off of already). It just barely fits on to the chamfered end of the PTO, until it hits the splines on the PTO.
Is there such a thing as a PTO reducer that would slide on my PTO, lock, reduce to the shaft size, and fit a cross-pin to hold this shaft on? Would really like to get this seeder working to plant food plots, spread fertilized and maybe lime.
/ PTO attachment for Cyclone seeder - help needed #2
It looks to me that someone was using a PTO pin to attach the drive shaft. That is the better setup in my opinion. This is what I did to mine. I could make you an adapter if you gave me the dimensions you need.
