PT425 Subaru Starter Blow Out @ 29 Hours
   / PT425 Subaru Starter Blow Out @ 29 Hours #1
FAZTRAC
Flatistan and Tenn. (part time)
PT 425 & john deere hydrostatic, DR Brushcutter 17 HP!!!!
New PT 425 with Subaru EH72. Hitachi Starter solenoid decides not to disengage at 29 hours. How unfortunate. I shut the motor off and the starter motor is still cranking until I could get a wrench and get a terminal off battery. Bench tested and did the same thing, once powered... would not disengage. Used all the smoke and mirrors I had to get the starter out without pulling the engine. Ended of drilling a hole through the side of the tractor in line with the upper, starter bolt head to get at it with a socket and long extension.The bolt head was buried behind electrical wires under tension. There would be no getting a socket on the bolt head without carefully watching and moving wires out of the way with a long screwdriver. Without hole you are working with mirrors and feel.XXXXXX!!!
Subaru wants to send me only a solenoid. It is true that the solenoid is the culprit, but how long was that starter motor running while I was working the tractor(I wear ear muffs)? I will never trust that starter to have a normal life span after this. We are in the middle of a massive project and we tried to get Subaru/Dealer to send solenoid Fed Ex overnight and told local Subaru dealer we would pay the overnight freight. No show. What a surprise.
Looked up Subaru/Robin parts on the Internet. Good luck getting parts for an EH72. I think I would stand a better chance of getting on the space shuttle. I see no parts look up for Subaru on the Robin web site. The dealer is new to Subaru.... says "their parts look up is very frustrating".
Does anybody else have a parts source? Thanks.
   / PT425 Subaru Starter Blow Out @ 29 Hours #2
The Robin website is
Subaru Robin
There are parts manuals there for several EH72 engines.
For example, the following link, page 26 shows a complete starter with part number and all of the internal parts exploded by number. Not sure if this is your engine, though.
http://www.robinamerica.com/media/manuals/129248179497999320.pdf
Moss
Thanks so much. I guess I was too aggravated to find anything.
Hopefully at least the solenoid will appear today. I fear I have become
too dependent on this wonderful little machine. It is amazing what it will do
FAZ
   / PT425 Subaru Starter Blow Out @ 29 Hours #5
Moss
FAZ
Yeah. I could sense the aggravation and urgency in your post. I, too, really have come to depend on out little green beast. So much so, that I have stopped using it for simple things just so I can get some physical exercise. I think I've gained 20 pounds just from owning it! :laughing:
   / PT425 Subaru Starter Blow Out @ 29 Hours #6
Try Continental Engines at 800-922-5632. I have had good results with them. Very knowledgeable.
   / PT425 Subaru Starter Blow Out @ 29 Hours #7
I will second jacks small engines.
Here is the EH72 starter motor assembly...
Jacks Small Engines Search
For $299, you might want to rethunk buying the whole assembly.
   / PT425 Subaru Starter Blow Out @ 29 Hours #8
You have found the main problem with the PT. You get fat. I now use a wheelbarrow for my firewood just to get some exercise.
   / PT425 Subaru Starter Blow Out @ 29 Hours #9
Using the PT to get the mail is a bit much as the mail box is only 100 yds.
   / PT425 Subaru Starter Blow Out @ 29 Hours #10
FAZ,
If you get desperate, I still have the OEM standard duty starter laying around. I doubt that it has been used for 50 starts. JackRobin sent me the HD version at no charge to try to fix my cold starting problems. I think it will fit in a USPS medium flat rate box.
JOHN DEERE 661R LOT IDENTIFIER 97 (A53084)
JOHN DEERE 661R...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
UNUSED X-STAR 20' X 101" LOADING RAMP (A51247)
UNUSED X-STAR 20'...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
