PT425 - Kohler - Throttle linkage problem
/ PT425 - Kohler - Throttle linkage problem #1
Carpenter
N.E. Oregon
PT425, Kubota L39 TLB
My 425's throttle has always been sort of messed up; The throw on the lever only goes up about half to minimum throttle and I'm not sure if I've ever had full throttle or not. The other day I lost everything above mid throttle so I decided to adjust the cable but I'm afraid I'll over rev the engine. Does the Kohler Command 25HP have a rev limiter or something to keep it from self destructing?
Thanks!
/ PT425 - Kohler - Throttle linkage problem #2
Thanks!
Yes, the engine has a governor. It sounds like the housing on your throttle cable has slipped, reset and tighten the clip that holds the cable housing.
Thanks, JJ. I figured it did but I didn't want to find out the hard way. :)
2026 tilt trailer (A56859)
2026 tilt trailer...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
LOT OF PLOW POINTS & SHINS (A60430)
LOT OF PLOW POINTS...
Honda EM3800SX Portable Gasoline Generator (A59228)
Honda EM3800SX...
2012 FORD F-150 XL EXTENDED CAB TRUCK (A60430)
2012 FORD F-150 XL...
