PT425 - Kohler - Throttle linkage problem
   / PT425 - Kohler - Throttle linkage problem #1
Carpenter
N.E. Oregon
PT425, Kubota L39 TLB
My 425's throttle has always been sort of messed up; The throw on the lever only goes up about half to minimum throttle and I'm not sure if I've ever had full throttle or not. The other day I lost everything above mid throttle so I decided to adjust the cable but I'm afraid I'll over rev the engine. Does the Kohler Command 25HP have a rev limiter or something to keep it from self destructing?
Thanks!
   / PT425 - Kohler - Throttle linkage problem #2
Thanks!
Yes, the engine has a governor. It sounds like the housing on your throttle cable has slipped, reset and tighten the clip that holds the cable housing.
Thanks, JJ. I figured it did but I didn't want to find out the hard way. :)
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
1995 GMC CHIPPER/BUCKET TRUCK (A53426)
1995 GMC...
1 pallet of Truck equipment (A53117)
1 pallet of Truck...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
(3) BRUSH GUARDS FOR TRUCK (A51248)
(3) BRUSH GUARDS...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
