PT422 electrical diagram
   / PT422 electrical diagram #1
Marks481
Platinum Member
Power Trac 422 (2005)
Anybody have an electrical diagram for the PT422? I checked the manual, and I have nothing.
In the right side of the engine compartment I have two connectors which are unplugged. A female bayonent connector on a white wite which has 12V when the ignition switch is on, and a male bayonent connector on a gray wire. Anybody know what these do? The tractor runs fine without plugging them into each other.
   / PT422 electrical diagram #2
Get an engine manual for your engine and it should show you what those are for.
I had some spare wires hanging off of my Kohler, and the Kohler manual had them identified.
Good call. The Robin America site had all the manuals online, and the engine manual had the diagram. The gray wire is the oil low pressure alarm. Sure enough, the oil pressure sensor wire is gray. I am thinking that I will hook it up.
   / PT422 electrical diagram #4
I hooked up the oil pressure switch to a light that I added on the console. I think it is a really good idea. The light sometimes flickers at low idle and I know to up the idle speed a little.
   / PT422 electrical diagram #5
Great! :)
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2018 HAMM H7 SMOOTH DRUM ROLLER (A51246)
2018 HAMM H7...
1/8" X 41" W X 81"L DIAMOND PLATE STEEL SHEETS (A51247)
1/8" X 41" W X...
UNUSED CFG HANG-ON PALLET FORKS (A51248)
UNUSED CFG HANG-ON...
(5) PARTIALLY COMPLETED TRAILER RAMPS (A51247)
(5) PARTIALLY...
