PT400 Series Operating Tips: Towing Implements
   / PT400 Series Operating Tips: Towing Implements #1
MossRoad
Super Moderator
Top Poster Of Month
South Bend, Indiana (near)
Power Trac PT425 2001 Model Year
Post any tips you have on towing implements behind the PT400 series tractors here.
When towing cheap plastic fertilizer spreaders behind your PT400 series tractors that have the exhaust pointing straight back out of the center of the engine compartment, it is advisable to use a heat shield of some sort or you may (will) melt the plastic handles. :p
   / PT400 Series Operating Tips: Towing Implements #3
Now just exactly how do you know this? .......Never mind my imagination just kicked in, How bad was it?
I have a Scott's tow behind spreader for lawn tractors. Everything was going fine until, about 3/4 way through my yard I saw no material being spread. Investigation reveals there is a barrel shaped device that you turn to adjust the opening of the spreader. By turning it you lengthen or shorten a steel cable. However, that barrel shaped device is made out of plastic. At the top of it, there is a metal pin (long pop rivet) that goes through a metal lever. You pull the lever, it pulls the pin, which pulls the device, which pulls the cable.
The exhaust heated up the metal lever, which heated up the metal pin, which melted the holes in the plastic device. As soon as the plastic pulled around the metal pin, it fused itself back together and cooled back down. It was solid enough that I could use an old nail to reconnect it to the lever and keep going.
However, I put an old metal slow moving vehicle sign between the exhaust and the lever to redirect the exhaust around the spreader handle. :rolleyes:
   / PT400 Series Operating Tips: Towing Implements #5
We can hope it wasn't ammonium nitrate...
Do you have brands to recommend?
All the best,
Peter
   / PT400 Series Operating Tips: Towing Implements #6
To me it is an art to backup a pt with a trailer (tow behind implement) Not one I understand.... I am the king of jackknife with a trailer...
   / PT400 Series Operating Tips: Towing Implements #7
LOL -- after trying it only once, I don't even try it anymore -- I make sure to only go into situations where I can pull through... :p:p
   / PT400 Series Operating Tips: Towing Implements #8
One of my first jobs involved parallel parking double hay trailers, in reverse. (Breathe deeply, think about it, and try again...) Later in life, it made parking 40' single trailers a breeze. (Oh and don't forget what soft ground will do to a trailer when backing up...)
It is funny how these things go, I find estimating where the tip of the LMB will be when backing up in tight situations surprisingly challenging. It seems so simple, and yet...
All the best,
Peter
   / PT400 Series Operating Tips: Towing Implements #9
I can back a trailer with my truck or other garden tractors OK, if I go slow. I'll admit that even though I grew up on a farm and learned to drive on an old 8N, I NEVER was able to back a 4-wheel farm wagon with a steerable tongue. If pulling through wouldn't work, I'd simply get off the tractor and let someone else deal with it, if necessary...
My problem with trying to back the PT with my 7-foot dump trailer behind it is that any steering movement is magnified incredibly -- much more so than in a normal front-wheel steer scenario. Because the PT has to articulate to steer, it really wiggles its rear which seem to make jack-knifing inevitable for me...
   / PT400 Series Operating Tips: Towing Implements #10
I usually pull a lawn sweeper behind my PT422 when cutting the lawn. Does a great job of picking up clippings (generally have to empty every 1/4 acre or so). So I have got pretty good at backing up with a trailer attached (and teh mower out front).
I need about 5 more Hp for this combination... on flat land.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A59905)
2013 KENWORTH T680...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2016 Ford Explorer 4WD XLT SUV (A59231)
2016 Ford Explorer...
