PT1850 Temp Gauge
/ PT1850 Temp Gauge #1
BWSwamper
PowerTrac
AT what temperature does the PT1850 engine typically run? The gauge seems to be marked in 30 degree increments on the bottom half (100-tick mark-160), but 40 degree increments on the top half (160-tick mark-240).
So far my machine is running a little above the tick mark between 160 and 240, which is either "190+a bit" (okay ?) or "200+ a bit" (a little hot?)
/ PT1850 Temp Gauge #2
For me that is about right. I believe the operating range is 160 to 200F.
Here is a nice schematic with details. I did have my thermostat fail, which caused some cylinder scarring.
  • Deutz Cooling .pdf
/ PT1850 Temp Gauge #3
I have the same concern.
It was hot out the other day so I paid specific attention to the engine temp and it was running just above "the tick" for a while, which I took for 210ish and then went up to about half way between "the tick" and 240, maybe 225+, so I shut it down. Seemed too hot to me, but this is my first Deutz. I haven't modified the cooling shroud yet, but I'm definitely going to go through the lube oil cooling system before I run it too much more.
/ PT1850 Temp Gauge #4
Do you have a laser heat gun? I hate pts method to indicating temp. How dusty is your mowing? How often do you blow the cooling fins out. I am on nights but I will post my cleaning tools and techniques plus the mod I did on my side door which makes cleaning way easier.
/ PT1850 Temp Gauge #5
I just use an engine cleaning wand to reach in and clean the fins. Using a degreaser works better than just air so I will use water/degreaser every couple of cleanings.
Ken
/ PT1850 Temp Gauge #6
So to clean out the engine radiator I use a shorter version of something like this...
Draper ABG5 Air Blow Gun Right Angle 56mm
Now if you have taken the deflector completely off this is not necessary. Like ken, I will run water through coils every couple of weeks. I would advise, though to not run the tractor after until it has dried otherwise if you have dust you will have mud (ask me how I know).
Also, this is the mod I did to my cover. It was when I was first learning to weld, not that that is any excuse. I used some cheap hinges, and welded a washer onto a nut so I could undo the one side by hand.
/ PT1850 Temp Gauge #8
Ken- is that aquarium bubble wand really what you use?
I use an engine siphon wand. Wet and/or dry.
Carl- do you still find your tinytach useful?
All the best, Peter
/ PT1850 Temp Gauge #10
Tinytac usefell? Nice to have a rpm indicator and a good digital clock. I have a plan that once my shop is up I will do a complete rewrite of my machine including a new dash with new gauges.
/ PT1850 Temp Gauge #11
/ PT1850 Temp Gauge #12
I'll get in there with the air hose too. I have a friend with a Deutz-powered ag tractor and he said that the temp gauge barely ever comes off the "cold" peg, even when doing some heavy bailing. That riser mod is definitely on the short list!
/ PT1850 Temp Gauge #13
Those Deutz AG tractor engines are a whole other level. Deutz makes ag specific oil coolers and cylinders for them. PT uses the non-ag coolers. (I think because they are cheaper and smaller) The ag coolers have close to 5/8 between channels with no metal fillers. So they tend to be BIG. I have used those things with an 1/8 of dust on them no problem, and really never seen the needle get beyond the low end of normal. I once ran one for a week 24x7, providing backup power. (The first 48 hours at 2500rpm, the rest of the time at about 1000- way quieter. And yes, we refueled it warm. When you can put your hand on the muffler, the ignition risk is close to zero.) We would clean the tractor perhaps once a year.
I loved those Deutz AG tractors. They were 15% more efficient than the water cooled competitors, and ran like tanks. Just too tippy for where I live now...
All the best,
Peter
P.S. you can retrofit an ag cooler, but fit will be an issue. I looked into it years ago. You would need to move the hydraulic cooler, and fabricate some cooling ductwork. I decided it was not that big a deal for me.
/ PT1850 Temp Gauge #14
Mine runs at 200 when everything is normal. I keep an eye on it and if it rises to 220 I call it a day -- that's usually a clue that a) it's pretty hot out and b) my ducts need cleaning. No mods. I use one of those cheap air cleaners like the links above. I also blow air through the generator (which is immediately to the right/rear when you have that shroud off). I fried a generator a few years ago and discovered it was completely filthy inside when I replaced it. And don't forget that air cleaner -- another source of load on the engine. And the fins on the oil-cooling radiator that's mounted on the cover.
McCormick X6.55 (A64126)
McCormick X6.55...
New/Unused Wolverine Mini Combination Bucket (A65583)
New/Unused...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
iDrive TDS-2010H...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
