PT1850 Alternator Conversion
   / PT1850 Alternator Conversion #1
AltavistaLawn
Instead of spending $500.00 plus on a new Deutz alternator imported from germany, I decided to retrofit a "one wire" chev. unit to the contraption.
I used a ford 300 six cyclinder alternator bracket for the lower and made the upper bracket. I removed the Deutz idler pulley, and used the factory bolts for the lower bracket. I had to modify the hood a little for this set up. ;)
I'll make a removable cover for the cut out. The u can check th eoil without lifting that heavy hood all the time.
   / PT1850 Alternator Conversion #3
I think you have solved the alternator problem!:) At the same time, you now have plenty of capacity for additional lights, 12 volt attachments, (seeders) ect. :p Nice job, I think we will see more of this mod.
Bill
   / PT1850 Alternator Conversion #4
What is the amperage on the STOCK 1850 alternator? For that matter, how do the generators stack up over the entire lineup?
Carl
   / PT1850 Alternator Conversion #5
Carl
The Robin 22 HP is 15 amps.
   / PT1850 Alternator Conversion #6
Carl
I looked at the engine website, the 2011 engine series SEEMS to have a 55-60 amp alternator. I don't know if this is the right engine or not--I don't have an 1850---I wish!:eek: I had thought the capacity was less than that. :confused: However, now that we have a prototype installation, just select the GM (or other) capacity alternator you need.:D
Bill
We finished hooking it up.
The voltage meter reads a steady 14 volts, the way it used to. So it seems to have fixed it.
But theres a strange side affect. With the new alt. unhooked, the fuel solenoid shuts off by the switch as it should; but with the alt. hooked and running, the fuel shut off doesn;t cut off, and the keys off alll electrical cuts off, except the fuel solenoid...so I have to manually shut off th fuel to stop it.
I think its some kind of ground loop. But at least its running good now.
   / PT1850 Alternator Conversion #10
It appears that you are feeding the plus side of the fuel solenoid with 12 volts, when running. You just might have to rewire the fuel solenoid with a separate switch.
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2016 HAMM HD+ 120i SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120i...
PALLET OF 6' X 12' SITE FENCE (A51248)
PALLET OF 6' X 12'...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
