PT1445 20 hrs, Lost steering!
   / PT1445 20 hrs, Lost steering! #1
PT1445Farmer
After reading everything on this forum about PT I finally picked up a PT1445 with mower, multi-bucket, boom, planter and spare filters plus hydro bleed pump, maybe a year ago. Possibly more.
20 hours of mowing - where it overheated every 10-15 mins, moving items as heavy as 1600 lbs with my homemade lift fork system ($100 instead of over $1000 for PT!), and towing things and I was relatively satisfied. Until yesterday.
Getting ready to plant a garden, I needed to use the multi-bucket to move loads of dirt. I uncoupled the fork carriage. The clamped in the multi-bucket. Shut off the PT and unhooked the hydro hoses and hooked them into the multi-bucket open/close hydro fittings. Started her up and ran. As I began shoving the bucket into the heavy wet dirt, the PT chugged and the engine stopped several times. I had the throttle at midway. Finally I got a bucket load, lifted it and started to back out. Suddenly it felt like the turning the wheel to the left had no resistance and almost no effect. I had lost my ability to get the left actuators to work with any force. They might work a litttle, then lose the force.
I had to let the dirt down to avoid tipping over, work the PT into the field and leave it parked.
What the **** happened and what can I do about it? Looking for help from my fellow PT1430 -1445 - 1460 er's.
Pre Thanks! Might even send a reward tomato or two if I can get my PT to help me plant.:cool:http://www.tractorbynet.com/forums/images/smilies/cool.gif
   / PT1445 20 hrs, Lost steering! #2
OK, first thing. Did you say lift and tilt work? If so, it is not your pump. Can you turn your tractor right (meaning, does one steering cylinder work and the other not?)
Two things... First, if the steering wheel spins freely, and you cannot steer left or right, give it a tug. My pin cotter pin vibrated off my steering wheel.
If you have to spin the wheel a lot to get it to turn right or left, I think one of your steering cylinders is clogged / failed.
You said the engine kept dying. If that is the case, you may be bypassing somewhere. Did you check to see if you accidently left on your PTO switch or bumped it on?
Initially I don't think your engine dying is related to your steering if you can lift tilt and dump but not steer.
More info please....
Woodlandfarms - I could turn to the right with full effect. I could turn a bit to the left on level ground but the cyclinders would not hold the position. The wheel was spinning easily to the left, without movement from the tractor. I had a bucket full of dirt and was just backing out from the hill when it became apparent that turning the wheel to the left had no resistance.
I initially thought it was a cotter pin or lack of connection with just the steering wheel. That does not seem to be the issue because I could turn to the right as normal.
I might have accidentally turned the PTO on, but I doubt it. Am going to my farm in TN on Tuesday but really need to have all my parts, plans, tools, and knowledge from the PT "Village Wisemen" - as in, you guys.
Yes, I agree that the engine dying and the steering issue are separate.
1. What parts do you think I need to get this going again? Unfortunately, my parts book is at my farm. Hopefully Terry at PT can get me set before I drive the several hours to the farm for repairing.
2. Recommended spare valves, motors, etc.? Willing to spend big bucks to not lose time in the future.
Thanks for the advice!
   / PT1445 20 hrs, Lost steering! #5
Just to confirm, you did check to see if you had blown a fitting or hose? No oil in the tub area or on the ground? I ask because a wheel that spins easily like that is a symptom of a blown steering hose.
I suppose it could still steer to the right if the rupture was in the left side circuit, until it ran out of fluid. If you did not let it run long, it might not have run out of fluid.
Whatever you do, you want to confirm that you aren't losing fluid before you even start it again. If you loose all your hydraulic fluid, the drive pump will be destroyed. They are very expensive.
   / PT1445 20 hrs, Lost steering! #6
The steering valve could have a defect in the left turn position.
I did not notice any fluid leaking though I did not look for any. Will check for one before starting her up again. Another inspection item I will look at when I check the tractor on Tuesday.
Since I do not have the diagram in front of me for the hydraulic system, I am guessing that there is a valve for each direction - right or left - and a control system for actuating the valve proportionate to the turn, plus the cylinder that moves the body in the desired direction. Hoses connecting everything.
That means buy hoses, one valve, and one servo controller - or whatever the mechanism is that translates the wheel turning into a proportionate cylinder move. Anyone have part no.'s?
Grateful!
   / PT1445 20 hrs, Lost steering! #8
I had something like this happen to my PT. Here is what happened I could spin the wheel to the left, and nothing would happen, I could spin the wheel to the right and it would go.. I got home doing right hand loopedy loops..
The problem was debris in my steering cylinder (the pistons on the left and right side of the seat). Inside the cylinder is some sort of a valve or gate and debris can stick it open, or it can just fail open. So pressure is lost through that piston. A little is backed up, enough to push the other cylinder a bit (You could kinda move in one direction, but really move in the other, right?)
If you grab a cylinder, turn the wheel, you can generally feel which one is getting pressure and which one is bypassing.
Do not do this unless you confirm with Terry, but I think if you pull the two hoses off the cylinder you feel has died and cap the hoses with a real cap, that will pressurise the other cylinder enough to drive it out of harms way.
I ripped one of my cylinders completely off due to a bad weld, but was able to steer, albiet slowly (one cylinder has to fill up completely before the other cylinder takes over the load or something crazy like that)
To repair, Terry sent me two new rebuild kits for the cylinder. Easy to pull of, but a NIGHTMARE to take apart. I actually had to take them in to a machine shop to have them opened, and the machine shop was very upset with me as they struggled.
This being said, You loosen the cylinder caps ON the tractor, using a large pipe wrench. Then unbolt and pull the pistons apart, put the new plungers in and slide it back together with ample oil to lubricate. JJ can tell you exactly how to do this. I did not do this, although I had planned to, because I could not get my cylinders apart. Someone at PT is very, very strong.
I have had my steering control apart on my PT due to a leak. From what Terry told me it is not a high failure area so I would put it on the steering cylinder. Also, if it fails it generally fails so you cannot steer at all.
As for a chart of hoses, you are SOL. You could spend money making up a raft of hoses, or just make maybe a couple of long ones and a couple of short ones but I would not do that. If you blew a hose, I am sure you would have noticed it. Oil would run down the center column and pour out the foot holes.
As for stalling, I still thing it is the PTO being switched on.
Carl
Woodlandfarms,
I think you nailed the problem. Your description of the problem sounds exactly like what I have experienced. Considering the PT was in a dirty, muddy, high grass areas it makes complete sense.
Going to call Terry right away and see what parts I need and the process required to get going again. I have a pretty solid machine shop including a hydraulic press so perhaps I can get this done myself.
Your help has been invaluable!
Thanks again one and all...Will be working on gathering the parts today, checking with Terry, and repairing the tractor tomorrow. Expect some good news shortly.
Just spoke with Terry. He wants me to unbolt the head of one cyclinder and see whether it is activating or not. WoodlandFarms - Based on your repair description, I will be able to crank the cyclinder apart and repair it. Very strange for it to happen so easily. Makes me think this is going to be a routine problem. Since the PT is in the muck often with all the rain we have been getting - 7" so far this month - this will be a routine I will have to execute often. Arrgggh. I enjoy driving and farting around with this PT1445, can't stand the thought of it going under the repair wrench. When she works, there is nothing better IMO.
I have a solid 60 hp 4wd tractor that runs perfectly but I hardly use because I enjoy the PT so much more.
Soosan 140 Hammer 30 ton Class (A52384)
Soosan 140 Hammer...
(INOP) CATERPILLAR CB-434 SMOOTH DBL DRUM ROLLER (A51247)
(INOP) CATERPILLAR...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
2016 CHEVROLET 2500 TRUCK (A51247)
2016 CHEVROLET...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
