davesisk
Platinum Member
PT1418 won\'t start!
OK, you guys know mine is 12 years old (2 year old engine) and wasn't maintained that well in the past. Well, I'm still playing catch-up.
Started to do some digging last night, but the thing wouldn't start. I got out the battery tester and checked the batt, 12 volts w/ no load, 9 volts w/ load. Looks like a failing battery, so I went and got a new one (450 cranking amps) and put it in.
Actually, I plugged the cables up first, and turned the key, and the engine turned over. I said "cool". So, I wedged the battery back down into it's spot (which is a challenge because the back of the frame is bent in about a 1/2", so it's a tight fit to get it in there). I then hooked the terminals back up, turned the key...nothing! WTF?
So, I apparently have a problem other than the battery. Best guesses:
1) Key switch is worn-out? (It does occasionally stick in start position.)
2) Kill solenoid is frozen in kill position?
3) Wiring problem (a short maybe)?
4) Starter is stuck?
Any suggestions about where to troubleshoot? Any hints appreciated!
Regards,
Dave
Regards,
Dave
