PT Tiller
   / PT Tiller #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
Does anyone know who makes the Power-Trac tiller.
I did find out that I can reverse the tines on the tiller. In normal mode, it turns in the fwd direction, and if you want reverse tilling, you reverse the machine while tilling. By reversing the tiller blades, I can reverse till in the fwd direction. Haven't done it yet but will try it.
Most of the replacement tiller blades are between $8 to $12, and case harden blades are a little more.
   / PT Tiller #2
AFAIK, Power Trac makes all their own implements. It's not their style to farm stuff out. They even built their new showroom/sales/administration building themselves.
   / PT Tiller
Is that the actual name, or is that an abbreviation for something.
   / PT Tiller #5
AFAIK = As Far As I Know. It is a common abbreviation on the net. I thought pretty much everyone posting here was familiar with it.
   / PT Tiller #6
You beat me again. Gonna start calling you one minute Moss, if you keep that up. :p
   / PT Tiller
I have never used the phrase. Here I was trying to look up what looked like a foreign name. So much for effort. And of course I didn't find anything.
Well anyway, I hope you are not suggesting that PT cut and bent and sharpened those tiller blades. I am not thinking so. I was trying to find a match for the blades. The blade manufacture suggest I send them one, and they will try to match. Several of the blades I found were sharp on the front and back side.
If anyone finds a match please post the info.
WITHIT A new phrase.
   / PT Tiller #8
Well, you asked who made the tiller, not the tiller blades.
   / PT Tiller #9
NO !!.. Not all of us old farts are privey to all those internet abbreviations or acronym's. Here's a new one....IYCSOTGDWTKMA...I'd be happy to translate that...but the reply would have to be deleted !!:p
   / PT Tiller #10
I'm probably older than you are. I can't help it if you don't keep up the times. :D
2011 Ford F-150 Pickup Truck (A50860)
2011 Ford F-150...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A48081)
2017 Mack GU713...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
