One of the design changes I have been contemplating for a while is the installation of a shroud within the PT hood. A while back I calculated the heat removal capacity of the hydraulic radiator on the PT. It has more than ample capacity (in addition to the heat rejection from the metal hydraulic reservoir) to remove the heat input such that the fan should cycle on and off in temps upto about 80F, even when working it hard. What happens is the hydraulic fan pulls engine and exhaust heat up through the cooler. (It works great in the winter since it heats up the oil prior to the fan coming on.)
The shroud would just be a flat piece of sheet metal bolted within the hood cage. It would extend from the top rear and slant down to end about mid point of the air cleaner cover. This would force the muffler heat and engine cooling fan exhaust out the side/rear of the hood and the hydraulic fan to pull in cool air from the front of the hood. The new exhaust design from PT probably helps somewhat, but I think this would help significantly. (At least on the 400 series, not sure about the 1400 or 1800 series)
Can't help but think of summer with this long winter. What do think! /forums/images/graemlins/laugh.gif
Duane
Duane
