Hi,
Saw an ad for a PT the other day and started considering a used PT 425. Seems to be priced right with a number of attachments. This would be a 4 season tool, I have about 2 acres at the base of a hill. Mowing, snow plowing, snow blowing, and a loader for dirt and ice would be the majority of uses. I live in snow country in Western New York. Do they do well in snow? Do the decks accept recycling blades? (I hate raking) How do they do on soft ground? I have 1,000# plus Bolens that sinks into the grass in spring and fall. Would this still be an issue? I see that the dealer monopoly can be expensive. I had been considering a green or orange tractor but this would also meet my needs.
Thanks in advance,
Jon
First, welcome to TBN! :thumbsup:
- What year is the PT425?
- Does it have the quick attach or are the implements pinned on?
- Which engine is in it; Kohler or Robin/Subaru?
- Mine does fine in snow on my flat ground with turf tires. It crabs like crazy in snow on side hills. If I had hills, I'd get chains for the turfs and I think it would be fine.
- I have the 60" power-angle snow blade. It works great! I can stack snow 6' high.
- I have no experience with the blower, so can't help you there.
- FEL is fantastic for such a small machine. Buckets, forks, snow plow, 60" finish mower, 48" brush cutter, a 2" receiver attachment. Be aware of the lift height, though. It will not load a pickup truck from the side. I have an 18' car hauler trailer, and I can load that just fine from the sides over 12" side boards, so it's not an issue for me.
- My mower deck has very small spindle bolts, so it may be hard to find mulching blades to fit. Also, since it's a rear-discharge mower, the entire back is open. Recycling blades work best on closed decks, because they supposedly keep the clippings up in the air longer, getting cut into smaller bits as they try and fall. With the open rear on the PT decks, I don't think recycling blades would do that much different from regular blades, but I could be mistaken. If it's any consolation, I rarely bag my clippings, only if I need some for the garden. Then I pull a lawn sweeper behind me to gather them. The PT mower does a fine job for me. It's not like a Simplicity or Ventrac in the quality of cut, but I find it very acceptable. We don't have a "show lawn" like some neighborhoods.
- On soft ground, the PT itself does fine. The front tires on the 60" mower deck are pneumatic. I tubed mine so I could lower the air pressure and not keep popping them off the rims. The rear wheels on the 60" mower deck are OK, however, if you turn tightly on soft ground, since they don't caster like the fronts, they will tear the lawn. The are hard plastic, so there's no way to air them down.
- My PT425 with me on it is right around 1500#. The weight is distributed pretty evenly. The 4 tires are all the same size. I've never had an issue sinking into the grass. However, my soil is mostly sand and sandy loam, which drains pretty quickly. I've taken it into some wet spots at the little league park and never sank it. But only you can be the judge of that. @ 1500# total, there's 325# on each tire. The tire patch with my tires is about 2X the area of my size 13 shoes with the air pressure down to about 8-9psi. So I'm making a wild *** scientific guess that me standing on 1 foot is 215#. I do know for a fact that If I don't sink in walking an area, I won't sink in driving my PT425. So you might be able to use that for a comparison.
Those are my experiences. Hope that helps.
