Grey:
I don't have any doubt that the hydraulics will keep the PT from free-wheeling. My 1845 also has disc brakes that automatically clamp on when the engine stops.
Three years or so ago, I lost a neighbor, who rolled his Kubota on a hill. No one saw it. My own reconstruction was that he started down the hill in 2wd and the rear started to slide because of the HST drag. He had nothing in the bucket, but no counterweight either, and he went over a bank next to the road. I heard that he didn't have his belt on, and apparently the ROPS pinned him. BYUBill's right:
<font color=red>"I would say that if you are going down a steep muddy grade and step on the brakes, you're going to slide. No matter what kind of tractor your on. Even the 'truly amazing' PT.</font color=red>
On the PT, it's not a matter of stepping on the brakes, but pretty sudden wheel stoppage if you release the forward pedal, so the effect is the same. Once sliding, steering is only a memory. I'd be very leery of going down a slippery slope with weight in the bucket. So a suggestion. If you put a ball hitch on the front of the Power Trac, and hitch your trailer, you can push the trailer backward with precise placement, and little weight on the PT to lift the rears. (You might still want to hang something on the back for extra weight.) For a few weeks, I've been pushing a 5 x 8 single axle trailer around and found it easy and precise, and hitching is just running the ball under the hitch and picking up. I park it, load it with the bucket, drop the bucket, hitch the trailer and take it to dump it, without leaving the seat. (I do have to be a bit lucky with alignment of the trailer hitch attach plate. Sometimes I have to get off and hitch that by hand.) To dump, the PT lifts the tongue high enough for all but the stickiest load.
