PT and Kubota boys working together
   / PT and Kubota boys working together #1
Barryh
Harpers Ferry WV - Mountains of Shannondale
Former owner of a P T -180 / Kubota BX-1500 .. A Craftsman Yard Tractor / John Deere 140 H-1 / Cub Cadet 108. And now ( Little Red ) a Power Trac 1425
My neighbor Nate next door, who I sold my 180 asked me to help him level several mounds of dirt.
He's having a pool put in and the Cat has piled up several large mounds of dirt. Here are a few pic's of the two machines working together. Along with the two grown boys, I mean men playing in the dirt with their toys. Hard to tell from this angle but I have a full bucket.
A few more. :p
The mounds are still there but are shrinking fast. I'm moving some into my woods area for use around my place. I have ditches to fill and want to build up my pond area. What the heck, here's one of my new Leinbach L7200JR post hole digger with 9 inch auger I picked up today.
   / PT and Kubota boys working together #3
Barry;
Great pictures!!. It looks like a great chance to compare the PT against the Bota.:D The shaft driven PTO PHD looks a **** of a lot better & stronger than Power-Trac's toy PHD ( I can say that....because I owned PT's PHD with the 6, 9, & 12" augur bits) :D
Rivco said:
Barry;
Thanks Rich, Advantage Kubota, It is a heavy- duty unit for sure over 200 pounds. I need to get myself some forks rigged for this tractor, my next attachment move.
Advantage Power Trac the unit of course, would have the addition of downward pressure and being able to see your progress from a front view. I may use my electric cylinder to rig downward pressure on my 3 point. As for comparison of the two tractors. There are many. A few obvious things that come to mind between the BX and 400 series PT's. The lift on the loader, Advantage Kubota. I can lift / pile or scoop dirt way up high very large bucket, the 425 may come close.
Advantage PT, I notice with the Power Trac is the larger front tires roll over ruts and ditches much better than Kubota. It can be a bit tipsy with a heavy load in route. I of course do not have my tires loaded or any ballast on the back which does make a big difference.
The Kubota does help compensate for the smaller tires when in 4x4 mode the front tire will pull out of the hole with no problem. I still like the larger tire for all around use and stability on the PT. :eek:
Speaking of carrying heavy loads through the woods. Another disadvantage with the BX. There is a plastic fan to help cool the hydraulics up under the back of the unit also your oil filter and some hydraulic hose's. If you run a stick through this fan and break a fin. It can be a major pain in the --- to replace also expensive.
They make an after market skid plate you can install to protect the belly, which I will get as soon as I can. The PT is pretty much protected other than the hose's around the wheels. Advantage PT.
cqaigy2 said:
Advantage Kubota, looks like a real tractor. :p
Thanks but if I went tit for tat, I think the Power Trac in a 400 series would come out ahead in capabiltiy. It would be very close though depending on ones needs in a tractor. ;)
   / PT and Kubota boys working together #7
I can get my wife to help me move dirt and she is prettier than a PT or Kubota. So advantage wife.
Why is looking like a real tractor better?:D
   / PT and Kubota boys working together #8
You got me beat, i can't imagine a tractor looking better then your wife. :eek:
woodlandfarms said:
Man, you have never met my wife ;-)
Ok, you now have our attention lets see a picture. ;) :)
Kuhn FC 4000 RG (A50123)
Kuhn FC 4000 RG...
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51247)
2012 VOLVO DBL...
PALLET OF 2" X 4" STEEL TUBING & SITE PANELS (A51248)
PALLET OF 2" X 4"...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
