PT AL-629 ( can it be done ? )
   / PT AL-629 ( can it be done ? ) #1
Beechwood
Well winter is setting in and my mad scientist mode is kicking in again, so I'm tossing this idea into the pt frying pan for some feedback.
IDEA:
Turn a 180, 422, or 425 into a 6 wheel drive ( configured like a GATOR 6x4 ) by extending the tub approx 20" and re-powering the PT with a 29 HP Kawasaki water cooled fuel injected engine and adding two more wheel motors the same size as the OEM motors on the 180, 422 or 425.
If I use the PT HUNT VEE as an example- the engine is a 25 HP powering 6 wheel motors. If the HUNT VEE only had 4 wheel drive instead 6 do you think the pushing and pulling power would be that much less ? I know the Hunt Vee is a skid steer configuration but I'm only thinking about - and interested in the added available power with 6 wheel drive instead of 4 wheel drive. You could then build a larger carry all and relocate the gas tank to take full advantage of the bed area. I've been scratching my head on this for a while. I hope this can of worms will generate some lively winter conversation.
   / PT AL-629 ( can it be done ? ) #2
If you're gonna play mad scientist, picture it with rubber tracks over the 4 rear wheels -- i.e. an articulated half-track... :D
an articulated half track !!!! I'm liking it already :cool:
   / PT AL-629 ( can it be done ? ) #5
These probably aren't strong enough (being designed for ATVs) but should give you some ideas...
Introducing new LiteFoot M3 and M3 Ultra-Ride rubber track tread
These wouldn't even require the second set of wheels...
According to their web site I would lose 25-30% top end speed because of the gear reduction- so if the top speed for my 180 is 7 mph. that wouldn't work out to well plus the increased ground clearance might be a safety issue.
   / PT AL-629 ( can it be done ? ) #7
That loss was for a higher-RPM, higher-speed application on an ATV. Not sure you'd lose as much on a low-speed application. Also, usually when you lose top-end speed, you're trading it for low-end torque...
But, the challenge would be trying to sychronize the track speed with the speed of the front wheels...
   / PT AL-629 ( can it be done ? ) #8
I think you would get more turf damage. The back 4 wheels would turn like a skidsteer. I like the big wheel 425 better. It might look like a WWII German Half Track, a little. You would also have to change the plumbing of the hoses considerable. If you continue to put the wheel motor in series, the wheel torque would drop. Probably need a bigger hydraulic pump for the wheel motors and a valve to switch between parallel and series plumbing for the wheel motors. Sorry to be so critical.
Woodlandfarms, Did you mean to say 3K Uninstalled ? I hope so.
Kent and Bob, you both bring up some good points, I don't know how much turf damage the 4 rear wheels would cause, Because of the pt being articulated it might not be too bad. Adding two more motors hooked up in series might be a problem but that's why I started this thread to get some honest feedback & knowledge - positive or negitive. If the idea is feasible it needs to be a simple straight forward modification. What other problems would there be doing this type of modification???.
(INOP) KOMATSU PC200LC-8 EXCAVATOR (A51246)
(INOP) KOMATSU...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A51248)
UNUSED FUTURE SB45...
John Deere 114in 5-Deck Fairway Mower (A51691)
John Deere 114in...
Unused Delta Crash...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
