Charlie_Iliff
Veteran Member
- Joined
- Jun 13, 2001
- Messages
- 1,896
- Location
- Arnold, MD
- Tractor
- Power Trac PT1845, John Deere 2240, John Deere 950, John Deere 755, Jacobsen Turf Cat II
Bubenberg, MossRoad, PtRich,Reds & other PT400 operators:
Time for an unfair question: In your "objective" opinion , is the quality of cut of the PT 60" finish mower as good as that of the professional lawn/golf course ZTR and walk behind mowers? I am referring to the top end commercial Exmarks, Scags, etc., which usually have baffles and channels underneath, high blade tip speeds, high lift blades, often doubles, and usually a faily high horsepower to cut width ratio.
I have been asked that question about PT mowers generally, but since I haven't even put the finish blades on the 72" rough cut deck, and haven't lowered the cut height, my current cutting is not lawn quality, and not nearly as nice as the Jacobsen 72" front mower.
I am asking only about the look of the finish cut. I think the quality of construction of the PT is equal to or better than anything else I've seen on any machine, and certainly the front mount convenience is unbeatable, not only for hooking and unhooking, but for mowing, as well. You can see where you're cutting, can mow under bushes, etc. and go nearly as fast as a ZTR. But would the most finicky lawn owner like the look as well as that of the good commercial decks?
Does anyone know the tip speed of the blades?
Anyone have experience with Gator or other high-lift blades, doubles, different sharpening methods, etc?
MossRoad: Your pictures look great, but how does the cut compare to a pro ZTR doing a similar area? (He can't pick up the flower pots or dig the holes, but is his finish cut just a little bit smoother and more even -- or not as good as ours?)
To put the question in TBN context: The PT will cut better than any compact or subcompact tractor, but will it cut with a professional ZTR?
