PT-425 Won't start less than 8 hours
   / PT-425 Won't start less than 8 hours #11
Re: PT-425 Won\'t start less than 8 hours
rip , i will be more than happy to share the info , still wonder who got the 422 and attachments from the guy in fla. wish i had the mower getting very tired of the murray with a massive 30'' cut lol /forums/images/graemlins/wink.gif
   / PT-425 Won't start less than 8 hours #12
</font><font color="blue" class="small">( Jay, If you find out, don't keep me in suspense.)</font>
I don't even have a PT and I'm curious too!
   / PT-425 Won't start less than 8 hours #13
Seeee !
Lots of folks want to know how things turned out, not just what started it.
Share and share alike.
Good Luck anyway
i GOT IT FIXED BY CONNECTING THE LOOSE RED STARTER WIRE THAT HAD BEEN DISCONNECTED BY THE JARRING OF DEBRIS REMOVAL. aLL IS GOOD THANKS FOR ALL THE HELP
   / PT-425 Won't start less than 8 hours #15
well im glad you got it fixed , sometimes its best to look for what you need in the last place you expect to look for it , so i guess we should always start there first lol /forums/images/graemlins/wink.gif
   / PT-425 Won't start less than 8 hours #16
by the way welcome to the forum here and the pt family , so where are ya from and what do you have with your pt . and how do you like it so far /forums/images/graemlins/laugh.gif
i HAVE A PT 425 AND LOVE IT. I'M LEARNING NEW TRICKS EVERY DAY ON THIS FORUM. I FOUND OUT MY CLICKING WHEN i DRIVE AND TURN WAS DO TO A NOT FULLY DISENGAGED BRAKE. i LEARNED THAT I HAVE A LOW LEFT TIRE EVERY MORNING BECAUSE I THINK I MAY HAVE A VALVE STEM PROBLEM OR GRASS IN BETWEEN MY TIRE SEED. I'D BE MORE INTERESTED IN WHAT I NEED TO DO TO REVERSE MY STUMP GRINDER BLADE. DO I NEED TO DO ANYTHING WITH THE HYDRAULICS? i CAN REVERSE THE BLADE. I ALSO WANT TO KNOW IF THERE ARE ANY GOOD TRICKS FOR THE FINISH MOWER CASTER WHEELS. THEY KEEP COMING OFF THE RIM AND DEFLATING. PAIN IN THE ****. GREAT FORUM YOU ALL AND IT HELPS SO MUCH.
   / PT-425 Won't start less than 8 hours #18
well if you would like the answers to those questions do a search on the forum and youll find the answers your looking for i cant remember where ive seen them but i have seen them on here there is a cure for the flats and the tire leak down . i just got my 60'' mower and love it , havent had a flat yet knock on wood but when i do ill look for the answer as a matter of fact i need to find out what hi temp grease most of they guys use on their equipment here i.e. the name and type of grease ........so to all those who see this id love your input
   / PT-425 Won't start less than 8 hours #19
The answer to the left front tire valve stem problem is to replace it with a rubber plug that doesn't protrude so far and catch so much of the grass that gets wound around the wheel. I have already had the problem too. First I tried having the valve stem reversed so that it sticks into the wheel, but it blew off after a few minutes mowing. (This might actually work Ok if the tire isn't overinflated. I think the tire store put about 30 lbs of air in it, and I was in a hurry to get it back on and get more mowing done before dark, so I didn't adjust it.) Oddly enough when I brought this problem up to Terry, he had never heard of it before.
The only real solution to the caster wheel problem seems to be replacing them with solid rubber tires. $47 from PT, but I am sure you can find them cheaper. Glad to hear that your starting problem was nothing serious.
David
   / PT-425 Won't start less than 8 hours #20
You can find the answers to your Stump Grinder Rotation questions, and many more, which you might never have even thought to ask, at:
PT-425 PROS & cons?? !
If you should need further clarification, please, do not hesitate to ask!!
With you being a PT-425 owner, I am surprised that you are apparently not among the nearly 5000 folks who have viewed that thread!! /forums/images/graemlins/blush.gif
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2015 Chevrolet 1500 Silverado Pickup Truck (A55852)
2015 Chevrolet...
2025 JOHN DEERE XUV 825M S4 UTV (A57192)
2025 JOHN DEERE...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
2017 Ford F150 (A55973)
2017 Ford F150...
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
Ikonx Zero-Turn Mower (A56857)
Ikonx Zero-Turn...
