PT 425 tub is leaking
   / PT 425 tub is leaking
I see. I'm pretty sure I'm going to put this on my things I wanna do myself to learn something list. Haven't done any welding since junior high but like I said, I did want to get a small wire welder like Hobart 140. It would be handy if/when something else breaks on the PT. Or I could always make garden art! /forums/images/graemlins/cool.gif Part of the attraction of the PT was that they are fixable in the field since they are so, ahem, crudely built. I guess one man's ugly is another's pretty.
Nice thing about steel is you can always fix it by welding in more.
   / PT 425 tub is leaking #12
What was the outcome on the leak on your machine? Did you get it welded?
   / PT 425 tub is leaking #13
What did you do to fix your leak?
   / PT 425 tub is leaking #14
JJ
Nothing yet. I am waiting for my friend to help me out. He told me we might do it this weekend. I'll let you know what we do.
   / PT 425 tub is leaking #15
JJ
</font><font color="blue" class="small">( What was the outcome on the leak on your machine? Did you get it welded? )</font>
I haven't done anything to fix mine yet either. It's not a big enough leak to be that concerned about yet. A positive way to look at it is that this is probably the most active of all leaks right now. The gas tank leaks at the cap (probably as pressure builds in the tank) and I can see this because the tank gets all dusty and it becomes quite visible where fuel runs out. I never run with an absolutely full tank. The hydraulic oil tank leaks all the way around the seal. Again, you can see the seepage around the edges especially well as the PT gets dusty. I have read that both of these issues (fuel tank and hydraulic tank leaks) are common.
Of course, then there's the hydraulic hose that was leaking from the day I took delivery. And I could add that to the mower deck that wasn't assembled properly..... But I digress. At the moment I'm contemplating a Hobart Handler 180 mig for eventually fixing that leak, taking on any future repairs, and possibly assisting me with the restoration of my '78 f150.
Funny how once you have a PT you have even less time than you did before because a long project list just gets longer. /forums/images/graemlins/confused.gif
   / PT 425 tub is leaking #18
JJ
We tried to fix the leak today. Drained the oil, took a grinder to the paint. Then we heated up the the area we were going to weld with a torch to dry the inside of the tub. Then we arc welded the bad spot. So far everything looks good. After it sits for a night and still shows no sign of leaking I will be happy.
Anderson 31ft T/A Flatbed Equipment Trailer (A51691)
Anderson 31ft T/A...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
2015 Chevrolet Impala Sedan (A55853)
2015 Chevrolet...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A55851)
Dvorak Model 3072A...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
2023 Kubota Z252KH-54 Zero Turn Mower (A57024)
2023 Kubota...
