PT-425 PROS & cons??
/ PT-425 PROS & cons??
Re: PT-425 PROS & cons??
I emailed Morton to tell them that I was having problems viewing their revised website. Lisa from Morton called to discuss the problems. Having admitted that I love my building but not the new website, she quizzed me about it, asked for pictures, and soon asked if I would mind having those pictures added to their website! Fighting back my usual shyness and modesty, I immediately replied: "Sure! That would be great!!"!! /forums/images/graemlins/shocked.gif /forums/images/graemlins/smile.gif
/ PT-425 PROS & cons?? #142
And best of all, you got your PT425 some great exposure!
/ PT-425 PROS & cons?? #143
</font><font color="blue" class="small">( Fighting back my usual shyness and modesty, I immediately replied: "Sure! That would be great!!"!! /forums/images/graemlins/shocked.gif /forums/images/graemlins/smile.gif )</font>
Yeah, right! YOU shy? NOT! /forums/images/graemlins/grin.gif
You devious bugger you.... /forums/images/graemlins/cool.gif
<font color="blue"> YOU shy? </font>
That's me: "Mr Shy" !!
<font color="blueclass=small"> You devious bugger you.... /forums/images/graemlins/cool.gif
/forums/images/graemlins/confused.gif !!???????!! /forums/images/graemlins/confused.gif
At 100 hours I decided that Hydraulic Oil would be more appropriate to use in the hydraulics of my PT-425 than the OEM Motor Oil!
See info at: ATH
Q & A About AMSOIL Synthetic Tractor >> ATH << Hydraulic/Transmission Oil (ATH), “ALL WEATHER”
1. Question:
What is the viscosity of ATH?
Answer:
The viscosity of ATH is SAE 5W-30. In the past, this product was labeled as ISO 46, SAE 30 which did not reflect the oil’s multi grade capability to function over a wide range of temperatures. However, the oil has always qualified for the low temperature viscosity requirements of 5W grade oil. Now, the oil is clearly identified as 5W-30 to reflect its multi grade capability.
2. Question:
Can I use ATH in cold to elevated temperatures, where other tractor hydraulic transmission oils are used?
Answer:
Yes, this oil exceeds the most demanding “all weather” specifications of both John Deere J20C and J20D and Ford New Holland FNHA-2-C-201.00 and FNHA-2-C-200.00. It has a high viscosity index to maintain its lubricity at high temperatures, and it flows at temperatures as low as –47oF (-44oC) for improved equipment operation and wear protection at low temperatures.
ATH can be used with confidence in all equipment combinations of transmissions, hydraulic systems, final drives, power take-off systems, hydrostatic systems, and wet brakes.
Now, at 200 hours, I am glad I did!! /forums/images/graemlins/laugh.gif
/ PT-425 PROS & cons?? #146
I switched to ATH this winter and am very pleased, cold weather starting improved considerably. How does it perform in hot weather? My concern is the 30wt vs 40wt in hot weather.
/ PT-425 PROS & cons?? #147
Sorry it took me so long to get back with my answer. Yes the new piece has 2" od pipe, and no I've had no more problems. I'm glad the replacement part is heavier duty. db
<font color="red"> CON: Dirt In Footwells
Problem: Dirt accumulates in the footwells of the PT-425. There is an OEM hole in the bottom plate of the footwell, but it is difficult to wash the dirt into that OEM hole due to its location.
Solution: Drill about a 1" hole in each bottom plate as far to the rear as possible.
Result: Dirt can now be easily washed from front to rear, and out the rear hole!
</font>
/ PT-425 PROS & cons?? #149
<font color="red"> Dirt In Footwells </font>
You mean you don't wipe your feet before you get on your PT?
For shame! /forums/images/graemlins/blush.gif
/ PT-425 PROS & cons?? #150
<font color="red"> You mean you don't wipe your feet before you get on your PT?
</font>
You mean if I wipe my feet I'll never again need TWO wrenches, a bunch of curses, and a half hour to clean my foot wells? I'm gonna start wiping HARD!! /forums/images/graemlins/tongue.gif
An 1845's finest feature - adjustable floorboards... /forums/images/graemlins/crazy.gif
Sedgewood
/ PT-425 PROS & cons?? #151
Clean footwells... what a concept! I kinda like 'em crunchy crusty m'self. I worried a while about the little hydraulic hoses, but they seem to coexist pretty well with the crud.
/ PT-425 PROS & cons?? #152
<font color="red"> Clean footwells... what a concept! I kinda like 'em crunchy crusty m'self. I worried a while about the little hydraulic hoses, but they seem to coexist pretty well with the crud.
</font>
I'll second that. Mine have been cleaned out maybe 3 times in 600 hours.. The hoses seem ok but it can be a chore to get at the treadle grease fittings. My biggest concern is having the pan rot out from the perpetually wet crud. But then I worried about that with my Bush Hog and it had barely started to rot by the time I sold it 35 years later. If PT lasts 35 years I'll need a walker just to get to it /forums/images/graemlins/tongue.gif
Sedgewood
/ PT-425 PROS & cons?? #153
<font color="red"> If PT lasts 35 years I'll need a walker just to get to it </font>
I think the guys in Tazewell are working on a quick attach walker in their secret skunk works right now. /forums/images/graemlins/smirk.gif
<font color="red"> If anyone hasn't noticed, the top of the lifting arms is a handy place to carry a half-barrel. Have the arms about level, and the toggle tipped forward. The barrel can be steadied with a free hand, or bungied into place.
When going out to plant a new shrub with the Potato Digger Bar, I carry a half-barrel of mulch with me. Half the mulch is spread on the ground to be stirred into the soil with the Potato Digger Bar, and the other half to mulch the surface around the new plant.</font>
<font color="red"> Stump Grinder Shield
Problem: My OEM Stump Grinder threw the chips at the front of the PT-425 and me!! It was unbearable and unusable!! I reversed the blade on the Stump Grinder to throw the chips away from us, but then, since chips were thrown in a wide forward shower, cleanup often took longer than the grinding!!
I tried several materials for a shield, but none were satisfactory. If it was stiff like plywood, it would break. If it was flexible, it could get back into the blade. A separate shield was too slow, and inconvenient, to use.
Solution: Traveling down the highway I spotted a tire tread about 9" wide by 7' long lying on the shoulder of the road from a truck that had a blow out and lost it.
Procedure: I cut and trimmed a piece 4' long with my 4-1/2" side grinder, (needed to cut the steel belts). Drilled two 3/8" holes, 6" apart, through the OEM steel shield. Doubled back the tire strip with the tread on the outside, and drilled two 1/2" holes, 6" apart, through the doubled strip to match those in the steel shield. Mounted the tire strip to the top of the steel shield with 5/16" nuts, bolts, and fender washers. Near the outward end of the tire strip, about 10" from the previous hole, I drilled a 1/2" hole through the doubled tire strip and installed a 5/16" nut, bolt, and fender washers to stiffen the new shield.
Result: The tire strip shield is flexible enough to move and conform to the ground to catch the chips, stiff enough to stay out of the blade, and tough enough to survive the abuse!
Cheap, and works great!!
</font>
/ PT-425 PROS & cons?? #157
14, have you started painting parts of your machine Gold now? Looks like the QA is Gold. I may know where you can get a nice set of reverse mounted chrome rims. They even have the thingy in the middle that keeps turning when you stop. /forums/images/graemlins/smile.gif
<font color="red"> 240 hours with reversed wheels and still riding sweet and safe with no ill effects!!!
</font>
/ PT-425 PROS & cons?? #159
Hi 14, good to here from you. Thought you had expired or something. Long time no see!!! Be sure and check for stress cracks in that frame and grind a deep grove in them before welding. LOL
All in jest but you got to admit the one earlier about the 3-in-1 oil can was a good one.
/ PT-425 PROS & cons?? #160
Fourteen,
I am considering doing the same thing to my PT. When coming out of my garage it is at a steep angle. I have to drive out sideways to miss the SUV'S it feels a little tipsy. I am thinking of ice when plowing if I were to start to slide sideways and it came to a sudden stop it might go over. Other places like my neighbors driveway go straight down. I would feel better knowing I had the extra stance. /forums/images/graemlins/shocked.gif
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
JOHN DEERE 2040 TRACTOR (A63291)
JOHN DEERE 2040...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2015 Chevrolet Silverado 2500HD Service Truck (A61573)
2015 Chevrolet...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63689)
2012 Ford F-150...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
