Oil & Fuel PT 422 with Robin engine fuel filter
   / PT 422 with Robin engine fuel filter #1
MuncyBob
Platinum Member
N Central PA
PT 422
I did a quick search and found mention of the gas filter...but can anybody give me a part number(NAPA or otherwise) so I can waltz into my local store and pick up one of these....with just over 200 hours I figure it's about time to change it? I was thinking about taking the original into the store with me but not sure if the counter boys will be able to accomodate me.
   / PT 422 with Robin engine fuel filter #3
It's a very forgiving application. Any 1/4" inline fuel filter, such as a Fram G-1 should work just fine.
Gravy
The Jacks Small Engine site shows 2 that are 1/4" inlet yet the microns differs....this is no big deal??? Wouldn't the finer filter slow the fuel flow?
   / PT 422 with Robin engine fuel filter #5
The finer micron might be for a fuel injected engine. In any case, unless it's a really tiny filter, it should flow enough for this application - it will just clog sooner. Personally, I don't use a small engine filter, as you often end up paying more and getting a much smaller filter. Since there's plenty of room, I use a standard automotive filter.
Gravy
I inquired at the local NAPA storte on a cross reference to the Fram G-1 mentioned above....FYI you can get the plastic filter part# 3001 or the metal filter with new clamps part#3031.
Just an update, the NAPA plastic filter would not intsall without leaking using the original spring clamps. Also, it is suggested that you take off the small rubber fuel line joining the fuel filter with the engine and inspect it...mine is severly cracked on the outside, intereior was ok but probably just a matter of time(not much probably!) before a leak!
   / PT 422 with Robin engine fuel filter #8
Good update. Wednesday, I replaced my fuel filter and both the short and long fuel hoses as part of my 500 hour maintenance. My short hose was badly cracked also.
Dale
KUBOTA L4600 TRACTOR (A51247)
KUBOTA L4600...
2011 BOMAG BW211 D-40 SMOOTH DRUM ROLLER (A51246)
2011 BOMAG BW211...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2023 JACTO JATAO-1000 LOT IDENTIFIER 67 (A53084)
2023 JACTO...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53472)
3-Point Hitch Root...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
