Pt-422 issues...again
/ Pt-422 issues...again #1
joseph8962
Monongahela, Pennsyvlania
Power-Trac
Ok so, it was indeed the starter which was the source of our problem however now we have a new one, when trying to place in the engine, a piece of the love joy coupling or spider jaw coupling the black either rubber or the plastic thing that goes in between the spindles of the engine to the other part, came out, can't find the rest of it, so it seems to of sheared off somewhere, and we don't have a part number for it maybe you guys can help us out, the specifics of the power trac is below, if there is any other information you guys need let me know.
Ok so found a peice on it that said L-100, then another that had 099, does that mean it's a L099 / L100 spider jaw then? i don't want to get the wrong part.
Power-Trac PT-422
Engine: Subur Robin Engine 22.0 Eh65.
/ Pt-422 issues...again #2
Take a look at the pdf found at this link for more details on the L100:
http://www.lovejoy-inc.com/DownloadPDF.aspx?file=/uploadedFiles/Catalogs/Jaw2010.pdf
From what I remember, you do have L100 couplers, and just need the spider (black) that goes with them. I think this might be it, but you should check to be sure:
Lovejoy 11494 Size L-AL 099-100 Solid Type Jaw Coupling Elastomer Spider, SOX/NBR Rubber, 2.54" OD, 0.61" Elastomer Length, 417 in-lbs Nominal Torque: Flexible Couplings: Amazon.com: Industrial & Scientific
Good luck!
/ Pt-422 issues...again #4
Yeah, maybe a buck or two... but if you are a Prime member you get free 2-day shipping on that Amazon link. ;)
The one Ebay link I found ended up being twice as much after shipping, an even the other Amazon deal (non-Prime) was cheaper. Plus easy returns if needed.
so we ordered a new spider thing, and let me tell you the tractor runs better than ever now, we also removed and cleaned the throttle thingy, and now the tractor is running great thank you everyone, but we have now run into another issue, is there a site where you can order parts for the pt-422? we need a female coupling for one of our hoses, as the original got crushed and we never ordered a new one.
/ Pt-422 issues...again #6
As PT (and maybe the previous owner) used all sorts of connectors, can you get the numbers and manufacturer off the old part? It usually is around the collar. There are a number of sources and cross matches and you might be able to find locally.
/ Pt-422 issues...again #7
If you're in a hurry, you can always call the Power Trac factory and order parts. They'll ship em directly to you in a couple days. 1-800-the-yard
2010 MACK PINNACLE (INOPERABLE) (A63569)
2010 MACK PINNACLE...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
JMR Tree Boom Skid Steer Attachment (A61572)
JMR Tree Boom Skid...
BOBCAT UTV ANGLE BROOM ATTACHMENT (A63569)
BOBCAT UTV ANGLE...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
John Deere 6200 Tractor (A64047)
John Deere 6200...
