Charlie_Iliff
Veteran Member
- Joined
- Jun 13, 2001
- Messages
- 1,896
- Location
- Arnold, MD
- Tractor
- Power Trac PT1845, John Deere 2240, John Deere 950, John Deere 755, Jacobsen Turf Cat II
Terry, at PT, gave me NAPA numbers on all 3 fluid filters. Engine oil NAPA 1342, Fuel NAPA 3358, Hydraulic Oil NAPA 1551. For the 50 hour, I changed all three and changed the engine oil. I had to pump a gallon of the hydraulic oil through the pump to purge the air, even though I carefully filled the replacement filter to the brim.
The hydraulic tank cover was seeping, so I took it off, scraped the gasket compound off and reglued it with Permatex RTV. Whatever PT used didn't work, It was seeping all the way around. Easy fix, but took some time.
One of the rear anti-scalp wheels on the deck is rubbing the frame. The tires are foam filled, and I parked it with that tire pushed sideways against something, It stayed that way. When it wears enough to be of concern, I guess I'll have to buy one.
This weekend, in addition to mowing, I loaded a trailer with logs, using the PT boom. I got a pair of skidding tongs from Northern Tool & Equipment. With them hung from the boom by a short section of chain, it was easy to pick up one end of a log, rest it on the back of the trailer, then reposition the tongs on the other end of the log, pick it up, and slide it on the trailer. It was significantly easier than the same system on the forks on the JD 2240, because of the ability to position the boom so easily side to side.
Moved a pile of brush with the hoe and thumb. That worked, but a true set of grapple forks would do better. Maybe someday.
