PT 1445 arrived yeterday! 95% good, 5% bad.
   / PT 1445 arrived yeterday! 95% good, 5% bad. #1
SMJ
Southern Indiana
Power Trac 1445
The PT arrived two hours early by private carrier even though according to the driver it rained steadily the last four hours of the trip. There were no scratches or apparent defects. I had read how the fuel tanks contained debris consequently, I used a magnet on a probe to check for contamination. The attachment shows what was left after 30 minutes of cleaning. If I was compulsive I probably could have got even more with another 30 minutes of effort. On the other hand the hydraulic oil tank had only one or two shavings after five minutes or so of searching. Because of the rain and I was only able to put five hours on the machine today. We have a driveway that has lots erosion. It has a twelve degree angle of slope. With the box blade and ¾ throttle the machine had no trouble whatsoever pulling mud and loose gravel up the slope. Other great thing is that even with sharp tight turns on wet turf very little damage was done with virtually no ruts. So far the machine has performed flawlessly. I’m glad I went to Tazewell and listened to Terry carefully because they are rewriting all of the instruction and maintenance manuals. The only instructions that came with the machine were for the engine. I will post other attachments showing the PT and the drive.
   / PT 1445 arrived yeterday! 95% good, 5% bad. #2
Congratulations on your new arrival how about some pictures
sg
On the drive.
From the seat.
Front shot.
Grapple, box blade, stumpcutter and PT
   / PT 1445 arrived yeterday! 95% good, 5% bad. #8
SMJ,
Congratulations. Glad you got it in good condition and it looks great. I am really enjoying using my new 425. Keep the pictures coming as you tackle new projects.
   / PT 1445 arrived yeterday! 95% good, 5% bad. #9
Boy that unit looks really nice - especially with the large turfs
- It looks a lot like the 1845 with single tires in size even though I know it is larger - also that has a 7ft lift right?
Good luck!
-EDM
   / PT 1445 arrived yeterday! 95% good, 5% bad. #10
My drive is about 1000' and curving with and "S" in the middle, up and down hill.
How hard was it to box-blade backwards? (NOTE - forwards being defined as a typical 3 pt tractor BB looking over your shoulder /forums/images/graemlins/smile.gif )
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2019 KENWORTH T680...
City of Lakeland (A51691)
City of Lakeland...
2015 Ford Econoline Box Van, VIN # 1FDWE3FL4FDA28220 (A51572)
2015 Ford...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A53472)
2015 Ottawa Yard...
