PSA- Another Farm related death
   / PSA- Another Farm related death #1
M5farms
Platinum Member
Panhandle
jd 2630 - NH TL100A-35 ferg-53 ford backhoe
LAst Saturday morning we found My first cousins husband dead under his 5' finish mower. He had been mowing Friday around some places on the farm and had gotten some hay string in the blades. He backed the tractor into its usual spot under the barn and used 2 4x4 wood blocks about 12" long standing in the ends under the edge of mower. he had removed 2 blades and apparently a block split down the center and mower fell and he died under this mower. Everything looked normal with the tractor under the barn and his legs were sticking out behind it and you could not see it unless you walked directly behind the barn. which his son did Saturday morning. he was searched for in the surrounding areas Friday night when it was discovered he was not in the house. Saturday morning early the sheriffs dept was there to help with a search when his body was found. Don't stand your blocks on end lay them down or better yet use jack stands that will not fail.
   / PSA- Another Farm related death #2
Wow....tragic accident. So sorry for your family's loss............a lesson to us all to be safe.
   / PSA- Another Farm related death #3
Sorry to hear that. Things on a tractor are heavy (FEL, Mower, etc) and I don't care how new and expensive your machine is- it all comes down to a little o-ring or nylon seal made in China. Please don't risk life or limb to save a few minutes.
   / PSA- Another Farm related death #4
Sorry for your loss. That's horrible.
I use jack stands when taking the 4" angle grinder to the mower blades. Heavy equipment that could fall and trap someone is always a possibility to guard against.
   / PSA- Another Farm related death #5
That's a brutal way to die. So sorry for your loss.
It's also a wakeup call for me, I've always preferred chunks off a hemlock over jack stands as I'm usually working outside and it's a lot more stable.
A few years ago I saw my neighbor doing a brake job using cinder blocks to support the car .:eek: I spun the truck around, went home and cut two blocks off a hemlock log I had just dropped.
He thanked me but argued "if they'll support a mobile home they'll hold up a car."
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
JLG 1255 Telehandler (A55315)
JLG 1255...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2013 John Deere 350G LC Hydraulic Excavator (A56857)
2013 John Deere...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
