M5farms
Platinum Member
- Joined
- Sep 1, 2014
- Messages
- 804
- Location
- Panhandle
- Tractor
- jd 2630 - NH TL100A-35 ferg-53 ford backhoe
LAst Saturday morning we found My first cousins husband dead under his 5' finish mower. He had been mowing Friday around some places on the farm and had gotten some hay string in the blades. He backed the tractor into its usual spot under the barn and used 2 4x4 wood blocks about 12" long standing in the ends under the edge of mower. he had removed 2 blades and apparently a block split down the center and mower fell and he died under this mower. Everything looked normal with the tractor under the barn and his legs were sticking out behind it and you could not see it unless you walked directly behind the barn. which his son did Saturday morning. he was searched for in the surrounding areas Friday night when it was discovered he was not in the house. Saturday morning early the sheriffs dept was there to help with a search when his body was found. Don't stand your blocks on end lay them down or better yet use jack stands that will not fail.
