prying(?) head off.....
/ prying(?) head off..... #1
stormpetrel
Block Island R.I.
ym2210D
I DID dig the tractor out......have the head bolts off. The head doesn't want to budge; I've tried some "dead blow" hits, prying, no luck. Any hints?
The other thing I'm thinking about is a temp gauge, so I only do this once:cool:
I seem to remember a special type of fitting....?
Any help appreciated!!:thumbsup:
/ prying(?) head off..... #2
I've heard of some people slowly turning the engine over by hand to free a stuck head (let the compression do the work). As long as you are SURE all of the bolts are loose I can't see that it would hurt anything. You should be able to just pry it off though.
Thanks Aaron. By "pry", do you mean trying to get something between the head & the block? All 5 bolts (ok, studs) are off....there are only five right? :laughing:
I did get my head gasket from Hoye, and the knuckle seals I'm about to replace. I must say, I couldn't be too much happier with the level of service I've gotten when I call with questions. Really excellent, thanks! (I knew there was some reason I dropped your name in the "I must buy a Yanmar tractor" video!!!!)
:laughing::laughing::laughing::laughing::laughing::laughing::laughing:
/ prying(?) head off..... #4
I wouldnt place anything between the head and block. Is there any kind of attachment point on the head? If so can use that to pull up? My preferred route would be to rotate the crank by hand and let the pressure break the seal.
/ prying(?) head off..... #5
OK, I'm old and sometimes not sure about things. I take it by the laughing face you are joking about the 5 bolts? If you have the 6 out you will do no harm with a sharpened screwdriver blade on the steel head and block by driving it in a little to break the seal. Must say, my experience most head gaskets don't stick that way.
I was joking, all six are off. I'm worried about damaging the head or block by trying to get in between 'em. Rotating the crank is a good one though, hadn't thought about that.....
I'll report back tomorrow after I try again.
/ prying(?) head off..... #7
The others have said what is probably the correct way to do it, turning it over by hand very slowly. However, I bet you could pull the compression release, or pull it part way, then "bump" the starter. I'm not saying it's right or smart, but it's something I would do if I couldn't get a socket onto the crankshaft nut. (As is the case with my YM240, with a shaft mounted pump off the crank pulley.) I would also leave two or three head bolts in loosely, just to keep it from bouncing off the ceiling.
Turning her over popped the head off......thanks!! It looks as if the motor has never been disassembled, if it has, you'd have a hard time telling.
One thing though: one of the studs came out. It didn't break, it's just that the nut and stud turned, with the result that the entire stud came out. I thought it may have broken, and was relieved. Is this a problem? Should I use two nuts to re-install the stud? If I do, can I use just the recommended head bolt torque? I would think it would be foolish to use more..........any thoughts?
/ prying(?) head off..... #10
Technically your suppose to use all new studs/bolts when doing head repairs, or is that just bolts... not sure? But if the nut comes off thats what id do, maybe some semi-permanant lock-tite as well.
/ prying(?) head off..... #11
You don't need to torque the stud in the block. Just make sure it screws in deep as others. Torque only needed for gasket compression.
Good, thanks!! I sent the head off for testing, should have it back in a few days. Looking forward to getting back to work!!!:licking:
/ prying(?) head off..... #13
As winston1 says, you don't torque studs into a block, at least not at any more than just hand tight pressure. What happens if you torque studs in to "recommended head bolt torque" is you are no longer applying the force to the threaded portion of the block but are likely running the stud threads into the area where the tap has stopped cutting threads and this results in a wedging action that can, if you are unlucky, cause a crack to develop in the block.
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2019 Toyota Camry Hybrid Sedan (A66738)
2019 Toyota Camry...
2007 Freightliner M2 112 Tri-Axle Dump Truck (A66736)
2007 Freightliner...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
PORTA POTTY (A68842)
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
