prying(?) head off.....
/ prying(?) head off..... #11
You don't need to torque the stud in the block. Just make sure it screws in deep as others. Torque only needed for gasket compression.
Good, thanks!! I sent the head off for testing, should have it back in a few days. Looking forward to getting back to work!!!:licking:
/ prying(?) head off..... #13
As winston1 says, you don't torque studs into a block, at least not at any more than just hand tight pressure. What happens if you torque studs in to "recommended head bolt torque" is you are no longer applying the force to the threaded portion of the block but are likely running the stud threads into the area where the tap has stopped cutting threads and this results in a wedging action that can, if you are unlucky, cause a crack to develop in the block.
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
LIGHT TOWER (A56857)
John Deere 24in Digging Tooth Bucket Excavator Attachment (A60352)
John Deere 24in...
2012 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2012 TROXELL...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
Takeuchi TL12R2 (A60462)
Takeuchi TL12R2...
