forgeblast
Elite Member
Just remember it will want to shoot or waterspout heavily the first year after you trim....try to keep those in check
If you take off any broken, ground-dragging limbs first - then its easier for higher pruning debris to fall to the ground and it might help get your ladder nearer the center of the tree.... and finish by making sure I can mow around the bottom.
This is always the source of my most premium fire wood.
I was once told, how severly orchards apparently prune their trees.
Looks like the upper third of that tree is beyond the reach of a harvest ladder. I would cut out everything obviously dead, then some out of the top along with many of the vertical suckers, to just reach that limit of 30% maximum per year. Repeat next year until every part of the tree can be reached for harvest. After that you can prune specifically for apple production. You should already be getting a couple hundred pounds or more, no?What would you do with this thing? It has some major rot in the limbs - great housing for birds.
