Proud Massey 231 owner
   / Proud Massey 231 owner #11
The spindle is what the bearing and hub mounts to in order to mount the front tire. Since a tractor has high ground clearance they lower the spindle by using a "drop". In the case with the Massey in order to get this "drop" they have a machined cylinder looking piece that mounts in to a housing that uses bushings as the wear item. I need to know what is the common procedure when installing new bushings. I will take to a machine shop, tired of fighting a loosing battle. Need to move Massey out of shop, since the International 684 is on its way.
Ream the bushing to size. DO NOT resize the spindle.
No need for a coolant filter. Change coolant every two years. Use quality ethyelene gylcol anti freeze and DISTILLED water. Add cavitaqtion additive if you like.
Be certain to use diesel spec enginie oil. I use 15W40 year around.
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
2006 Ford Taurus SE Sedan (A55853)
2006 Ford Taurus...
Mobile toilet with shower (A55758)
Mobile toilet with...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
