protecting a concrete floor
/ protecting a concrete floor #1
jack707
Veteran Member
up North wisconsin
farm trac 555
Is there anything else I can use beside fire blanket to put on the floor to protect it?.
/ protecting a concrete floor #2
Big assumption on my part here......
Wanting to protect your floor from welder and/or cutting torch slag??? I don't use anything on my floor. Small particles are no problem. If I'm using a Plasma Cutter or Cutting Torch I am conscious of larger molten pieces that land on the floor. A gentle nudge to move them a couple times til they cool off prevents popping of the concrete. Been in my shop 7 years with 99% of my metal work happening in one area. You hafta look very closely to find any damage.
/ protecting a concrete floor #4
When my shop first got built. I went through a stage of trying to protect the floor. Then I just gave up:eek:. But if I'm doing a lot of cutting in one place I lay down a good size sheet of 16-GA to protect the floor.
/ protecting a concrete floor #5
I don't do anything to my floor. We don't use a cutting torch inside very often, and a welder doesn't produce big enough slag to hurt anything.
I will go with 16ga. sheet metal, the reason I asked is because I see some pitting on the concrete under my welding bench. Thanks
/ protecting a concrete floor #7
I weld and cut all the time in my shop. The only time I have damaged the floor was when I did about 50' of cutting on 2" plate. The massive amounts of slag hitting the floor made it pop even though what I was cutting was 4' off the ground. Normal light duty stuff has never hurt my floor.
/ protecting a concrete floor #9
Hardiboard or equivalent in other brands in comes in 1/4", 4'x8' sheets. I use it on my table to keep from burning the plywood below and it's better than a metal top because your slag won't stick. It works!
I believe the 1/2" thick is only in 3'x5' sheets. It will show burn marks if a torch if left in place for too long but will not burn through unless you are careless.
A couple of sheets will cover a 8x8 area.........set your project on top and you are good to go.
/ protecting a concrete floor #11
I just lay down a few equal sized pieces of angle like a upside down V. The air space is enough to keep from popping the concrete.
2020 Peterbilt PB337 S/A Dump Truck (A61573)
2020 Peterbilt...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 BOBCAT E42 MINI EXCAVATOR (A63569)
2020 BOBCAT E42...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
1761 (A58375)
1761 (A58375)
