Pros/cons of rotary cutter mounting systems? 3-point vs semi-mount vs trailer
   / Pros/cons of rotary cutter mounting systems? 3-point vs semi-mount vs trailer #1
Sigogglin
Goshen, VA
New Holland TC45DA
I've seen the standard 3-point hitch, the semi mount which seems like just the hydraulic lifts, not top link, then the tow behind.
What do you like about them? I have a couple.
3-point - it is nice when you want to back up and "push back the forest" when clearing the pasture edges.
Tow behind seems to provide more mower capacity per HP, at least from what I've been reading. True?
I'm looking at a John Deere MX8 with semi-mount. What is the value of semi-mount vs the others?
thanks
david
   / Pros/cons of rotary cutter mounting systems? 3-point vs semi-mount vs trailer #2
I am not aware of any capacity per HP gain of tow behind?? Curious what you base that on?
I believe semi-mount allows a smaller tractor to handle a larger cutter and still be able to easily "back" it.
I have a 6' mounted and a 15' tow behind.
Last summer I sold a 10' mounted. It was a load on my M9540. Required 1200lbs of suitcase weights. Good cutter. Just a bit heavy. Maximum width I'd want in a rigid frame.
   / Pros/cons of rotary cutter mounting systems? 3-point vs semi-mount vs trailer #4
   / Pros/cons of rotary cutter mounting systems? 3-point vs semi-mount vs trailer #5
I have only used the 3pt types. On my property, I have no need to attach the top link as I have no reason to lift the entire cutter.
   / Pros/cons of rotary cutter mounting systems? 3-point vs semi-mount vs trailer #6
General rule of thumb is 5 PTO HP per foot of cut. 3 point cutters in the larger widths weigh more and require tractors with more weight, longer wheel base, and sometimes front weights.
I ran a nice 6 foot Brown 472 with a 52 HP 4610 SU Ford. Plenty of power but even with 5 front suitcase weights the front would get light with an 1100# cutter attached. The Ford had a 77-1/2" wheel base
I currently run a 10 foot mounted Titan cutter that weighs close to 1500# with a T4.75. It is a perfect match IMHO. The NH has an 83" wheel base and weighs over 9K with loaded rears and FEL.
My father ran a 1800# mounted Howse cutter attached to an 805O Allis with 150 HP at the PTO. The tractor did not have front weights and got light in the front with that cutter attached. Perfect example of a short wheel base higher HP 2WD tractor without front ballast and a heavy 3 point mounted cutter. I ran it several years without any issues other than the front end getting light.
   / Pros/cons of rotary cutter mounting systems? 3-point vs semi-mount vs trailer #7
I like a pull type. Its mows better with less scalping as it follows better. Also, you can back it under trees easily. I use a rear mounts camera. Works awesome. Only disadvantage is crossing ditches. Much better on slopes. Pull type is also easier to hook up and can be moved around with a pickup truck if necessary. 20181026_120043.jpeg20180911_172837.jpeg
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A58018)
2005 PETERBILT 379...
2017 Freightliner Bucket Truck (A55973)
2017 Freightliner...
Entyre Chip Spreader (A57453)
Entyre Chip...
2013 John Deere 650K Crawler Tractor Dozer (A56857)
2013 John Deere...
2014 GENIE Z-60/34 BOOM LIFT (A52709)
2014 GENIE Z-60/34...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
