Pros/Cons of Kubota BH92 vs Woods BH90X
   / Pros/Cons of Kubota BH92 vs Woods BH90X #1
EastTnFarmboy
East TN
Kubota L5240 ROPs FEL, JD LX277, Ferris 3100Z
I am considering the purchase of a backhoe for my L5240. I currently have no rear remotes. Just curious about these two options and which might be best considering my tractor and current set-up.
   / Pros/Cons of Kubota BH92 vs Woods BH90X #2
I have a 5240 with the bh92 and two rear remotes. The hydraulic connection for the hoe is much bigger than the remotes. The bh92 is very easy to put on or off and seems to be very strong (I haven't used it that much yet).
   / Pros/Cons of Kubota BH92 vs Woods BH90X #3
at one point woods had a leg up on Kubota, now.. I think thats gone. I'd proably go with the OEM hoe.
   / Pros/Cons of Kubota BH92 vs Woods BH90X #4
Can't comment on the Kubota BH 92.
I have a Woods BH90X and it is very easy to put on and remove and does everything one could ask from it. The thumb, manual or hydraulic, is worthwhile as well. If the Kubota doesn't have the thumb that might be a factor. Look at the specs and compare each against the other.
   / Pros/Cons of Kubota BH92 vs Woods BH90X #5
Kubota, better ground clearance.
Higher hinge point closer to the tractor.
Built for the tractor, by the same people who designed the tractor.
2004 TerraGator 8104 (A53473)
2004 TerraGator...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
2017 Chevrolet Silverado Schwarze SuperVac Updraft Sweeper Truck (A51692)
2017 Chevrolet...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
