Properties of a reclaimed asphalt surface?
   / Properties of a reclaimed asphalt surface? #1
awl51
marlboro, ma
Kubota BX1500
Surfacing the driveway/parking area at the new place in Maine was the last major item after all the heavy trucks were finished with their building supply loads. The base rock was all down and well compacted, and I had decided that I wanted a reclaimed asphalt top course. I had 16 yards of RAP delivered the first week of December - much later than I would have liked, but there you go -- spread it with the loader and box blade, and went over it twice with a plate compactor, resulting in a 3-4" layer over about 1000 sf. When I got finished, it looked pretty good, was reasonably smooth, and was pitched well, so I was happy with the result. However, we had a downpour the next week, and the RAP turned soft - I could lightly drag a spadepoint shovel across it and start gullying the surface. When it dried out a little, I ran the compactor over it again and it firmed up somewhat. Shortly thereafter, the ground froze over, so I'm done experimenting with the drive until spring.
So, my question is, what can I expect for eventual performance for this type of surface? What's been the experience of other folks out there? I initially expected a surface that was pretty solid once it got compacted and consolidated. Do I just wait for warm weather or more traffic for it to set up with a firmer surface? And, if so, will the surface firmness likely be permanent, or should I expect it to vary with conditions (e.g., would it regularly tend to be more friable in spring?)
Oh, and one more question for those of you with reclaimed asphalt drives - has anyone been tempted to use a slurry sealer (the thick heated commercial stuff, not the 5 gal brush-on asphalt driveway 'sealers') to really smooth out the surface?
Thanks in advance.
   / Properties of a reclaimed asphalt surface? #2
I did a portion of my drive some 12 years ago and the only compaction was a loaded dump truck with bald tires. That material was chunky and needed to be broken and spread with a backhoe.
It has held up very well! Everything kinda fused together like real pavement.
Recently I purchased a couple of yards of 'prossesed' recycled and it is just not the same. Almost looked like they added 'dusty dirt' and it would not stick or compact.
Only advantage over gravel is that it does not wash out in heavy rains.
As to sealing, my opinion is that only a solvent type sealant would be of use as most commercial sealants seem to be water based.
I inquired as to buy what they use commercially and found that there exists a liquid that they use when they overlap paving runs.
Here they call it "collase'. I'm shure that is a local term.
You probably have seen workers with watering pails dribbling that stuff at laping joints.
Being fairly costly I did not try it.
What I have observed is whenever I might spill gas or fuel on pavement it first disolves but later sets up nicely.
My guess is that that seam joint liquid is a mixture of tar and solvent that quickly evaporates.
Heat and sunlight is your friend with that recycled material, so come hot summer you could just be in great shape.
   / Properties of a reclaimed asphalt surface? #3
We had our steep asphalt drive that was 20+ years old and cracking, coated with that slurry stuff. It really improved the surface and I'm sure it greatly extended the life of the driveway.
Out in front of my other place, the city had a slurry put on a couple of years ago and it seems to be a great thing. It was soft for a day or two and it set up to a kind of stretchy/sandy tar. It has now settled in and seems very good.
At first that stuff just seems like a thin coating that won't do much, but it seems like a good way to stop cracking and moisture damage.
   / Properties of a reclaimed asphalt surface? #4
Talk to a local paveing contractor and find out what they use for "Tack Coats".:)
   / Properties of a reclaimed asphalt surface? #5
Don't expect it to be like a true hot mix ashpalt driveway. They can kind of pack in a seal pretty good. A lot of it depends on how "rich" the used ashpahlt is. Ashpalt kind of dries out over time and breaks down. If it is a mix that is dried out and doesn't have a lot of asphalt in it, don't expect it to be much better than gravel.
   / Properties of a reclaimed asphalt surface? #6
Please post some pictures - so those of who are stuck in a cubicle dreaming about the weekend have something to look at :D
Hope it works out. We hope to do a driveway this summer.
   / Properties of a reclaimed asphalt surface? #7
Like the 1st reply mentioned, you won't see much benefit over the gravel until you get some heat. The remaining asphalt will soften, and if you compact again this summer (wait till its a scorcher), the mix will gain more density and will actually smooth out some more. After that, the mix will act as solid as normal blacktop during the cooler seasons.
Tack Coat is an asphalt water based emulsion that is used at joints and between layers of pavement as a bonding agent. Do not use this as a top coat. It will stick to everything and cover your tires, car body, shoes, floors, etc. Its very tough to clean.
   / Properties of a reclaimed asphalt surface? #9
True - a fine sand will keep it from sticking to you. We've also used sand blastin slag (Black Beauty) as its very fine and black.
   / Properties of a reclaimed asphalt surface? #10
A top coat of seal and pea gravel rolled on will set it up quite well, if it is an oily seal.
Be sure to have the surface packed and level before applying the seal coat. Reclaimed can make a very fine driving surface. But not until it is sealed.
Just spraying used motor/hyd oil on it will also tack it together.
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A53424)
Year: 2017 Make...
1274 (A50490)
1274 (A50490)
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2017 Chevrolet...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
