Proper use and lowering of heavy 3 point implements on TC29
   / Proper use and lowering of heavy 3 point implements on TC29 #1
TractorDale
fairfield, ct
TC 29DA
When lowering a very heavy 3 point chipper back to the ground I try to do it smoothly to avoid unnecessary strain or wear on the tractor, but it is difficult to prevent a bit of bouncing unless I just slam the lever forward and let the chipper drop.
Is there a right or better way to lower heavy 3 point implements so as to protect the tractor? Can the hydraulics and mechanicals that move the arms break if not used correctly? Should the tractor be running when the arms are lowered?
Thanks for any advice.
Dale
   / Proper use and lowering of heavy 3 point implements on TC29 #2
I'm not sure it's good for your chipper to just slam it down. There should be a valve between your legs or feet which controls the rate of drop of the three point. When you tell the three point to lower it will lower whether the tractor is running or not. It lowers by gravity not hydraulic power.
   / Proper use and lowering of heavy 3 point implements on TC29 #3
On my TC45DA the three point lever was really stiff and it made it hard to move smoothly.
There is a castle nut where the shaft goes into the case and loosened it and it helped.
   / Proper use and lowering of heavy 3 point implements on TC29 #4
There should be a rate of drop of 3 point lift knob that is in front of the OP seat. it has a turtle or wabbit sign on it , rotating in the direction of turtle reducing the rate of hyd flow dump to lift spool valve hence slowing the 3 point drop.
JC,
   / Proper use and lowering of heavy 3 point implements on TC29 #5
Thanks everyone. Very helpful.
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
2019 Dodge Charger Sedan (A55853)
2019 Dodge Charger...
(APPROX 32) 6' X 12' HEAVY CHAIN LINK SITE PANELS (A54757)
(APPROX 32) 6' X...
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
